ok this might sound a little weird question about the speedometer
Old Aug 9, 2010 | 07:05 PM
SKS Immortal's Avatar
Car: 1991 chevy rs camaro
Engine: 350 tpi 5.7
Axle/Gears: 373
ok well i own a 1991 chevy rs camro. it was my brothers and he got an 87 iroc with a bad body so he put the motor and stuff into the 91. ok so here is my problem. when he switched everything he put the 87 dash into the car. when he was switching out the cluster the speedo needle busted off. so my question would be does any 1 know where i can get a hold of a speedometer for an 87 iroc? btw the gage reads 145 and i kinda want it to stay that way.
plz lmk if any 1 knows where i can find one. ive been looking all day and cant find one...
Old Aug 9, 2010 | 08:49 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: ok this might sound a little weird question about the speedometer
You might consider placing a wanted ad in the site's classifieds.
JamesC
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Goto a scrap yard and pull a needle off of a speedo or tach from another camaro. Push it in at the zero point.
Old Aug 10, 2010 | 07:10 AM
Engine: 350 tpi 5.7
Axle/Gears: 373
will this work? i mean i have considered this but doesnt it have to be the same needle that came off of the car?
well that throws the needle out i had my dad look at it and apparently it busted off so i guess i gotta buy a new speedo...
Old Aug 10, 2010 | 07:27 AM
JamesC's Avatar
Yes, it'll work, provided you can remove the needle in one piece. As you might imagine, the plastic after 20+ years is fragile. And it means you'll probably have to experiment to make the speedo read correctly. Oh, be careful: If you bend/break the metal rod that the needle attaches to, you're pretty much out of luck.
I have a 145 that I sent in to have repaired long ago (factory fixed trip odometer), but it bounced a bit in my car. $25 shipped as is, if you're interested. I believe the pic below is the one in question.
JamesC
Attached Thumbnails ok this might sound a little weird question about the speedometer-100_0288.jpg
Old Aug 10, 2010 | 07:57 AM
Engine: 350 tpi 5.7
Axle/Gears: 373
JamesC
yeah thats the one that i need but what do u mean it bounced? my dad is the one that wont let me drive her w/o the speedometer and he doesnt want to get a messed up one.
Old Aug 10, 2010 | 08:09 AM
JamesC's Avatar
The speedo would bounce/twitch three or four miles an hour--at least in my car, which is why I'd only sell "as is." You'd be gambling.
JamesC
Old Aug 10, 2010 | 08:19 AM
Engine: 350 tpi 5.7
Axle/Gears: 373
yeah i told my dad about it and he said he wldnt want to get it. which i understand as this is my first car and he wants everything working right. what he doesnt realize is we have been driving the car w.o a speedo for close to 5 years now
Old Aug 10, 2010 | 04:13 PM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Ok like the poster above said did the needle itself just break? Or did the internal part break? I am guessing the needle itself cracked off which is an easy fix I posted what to do.
Old Aug 10, 2010 | 05:24 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
ive never seen a speedo that doesnt bounce a bit in these cars except for an aftermarket one, these things are so old theyre gonna have a bit of an error, mine bounces under 10mph and when im on the freeway itll twitch maybe 1mph every so often if you want accuracy youre either gonna have to hunt down a good factory speedo or go aftermarket
Old Aug 11, 2010 | 08:37 AM
Engine: 350 tpi 5.7
Axle/Gears: 373
just to keep you all updated. i took the speed gage itself out and looked at it to see what exactlly happened. the piece in the gage that the needle slides onto busted off in the needle. so no i guess i gotta buy a new 1
Old Aug 11, 2010 | 10:35 AM
Engine: 350 tpi 5.7
Axle/Gears: 373
JamesC
would u take 20 for it? sorry but my dad told me to ask
Old Aug 11, 2010 | 10:41 AM
JamesC's Avatar
E-mail sent.
JamesC
Old Aug 11, 2010 | 11:03 AM
Engine: 350 tpi 5.7
Axle/Gears: 373
E-mail sent.
JamesC
ty and i msged ya back when ya get a chance e-mail me back
Old Aug 11, 2010 | 11:59 AM
lozantius82's Avatar
Car: 89 Camaro Iroc Z
Transmission: MK6 World Class T5
Axle/Gears: 9 bolt had 3.45's, now 3.27 gears
I am interested in the guage, so 25 dollars only?
Frozer!!!
Jan 19, 2024 04:55 PM
Cleotiz
Jan 6, 2018 08:56 PM
CORV3TT3
Aug 23, 2015 11:26 AM
redmaroz
Aug 16, 2015 11:40 PM
gwade12
Aug 8, 2015 08:17 AM
