Auto meter gauges
Old Aug 18, 2010 | 01:43 PM
86vairoc's Avatar
Auto meter gauges
Hello im new to theforum but not new to "forums" I've been searching for older threads concerning installing autometer gauges, im not sure what is needed besides the gauges i have the fuel, temp meter, What would i need to install the speedometer and tachometer? i removed the cluster out thinking i could wire and splice these guages and meters using the factory hooks up but thats not going to happen any input is useful
Old Aug 20, 2010 | 07:57 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Re: Auto meter gauges
If your putting in a electronic speedo in,you'll need the sender in the link below.tacho needs power,ground and tach signal wire.Fuel gauge needs,power,ground,and fuel level sender wire.Temp gauge,needs power,ground and connection to the temp sender at the left side head.This applies to electrical gauges,not mechcanical ones.
http://autometer.com/cat_accessoriesdetail.aspx?vid=114
Old Aug 20, 2010 | 06:56 PM
383 Power's Avatar
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
You need to make sure that you have THE RIGHT fuel Gauge. The senders have different voltages depending on the Make of the car. If your original wiring harness is intact, you can just get a Diagram of your car and trace based on color. That's what i did. Took about an hour of sitting in a hot car, but it was well worth it.
Bubbajones_ya
Jul 6, 2024 08:32 PM
88rscamar0
Sep 23, 2015 09:08 PM
eustodp
Sep 20, 2015 05:09 PM
TrevinE
Sep 14, 2015 03:20 PM
86IROC112
Sep 11, 2015 04:04 PM
