rear trim connector
Old Aug 19, 2010 | 08:32 PM
gta90's Avatar
Car: 1990 GTA (T-Top)
Engine: 305 TPI (LB9) / 115k miles
Transmission: 4L60 (MD8 non-E)
Axle/Gears: 2.73 (GU2) 28 spline POSI (G80)
rear trim connector
I'm trying to remove the rear most trim panel. One connector seems stuck on. Its the one that goes to those metal plate sensors for the hatch. The plastic connector seems to have a latch that I was able to open. The connector is loose but stuck on. Any ideas how to remove it?
Update: got it removed. The square trim piece securing the metal plates needs to be removed first (2 screws). Once that's off, look on the back side of the plastic connector and the latch part will be exposed. Unlatch it and waalaa!
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
