Anyone done this or seen it done
Old Sep 1, 2010 | 01:59 PM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
Im planning on taking a crappy dash pad I got out of a junkyard and fiber glassing it then bondo-ing it then airbrushing some wicked graphics on it. I have searched and searched but I have not seen anyone do this before. If you have or know of someone who has let me know how it went, post some pics etc. Also let me know what you think of this idea I plan on posting pics and my progress as I go.
Old Sep 1, 2010 | 02:08 PM
lasher_350's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
Re: Anyone done this or seen it done
I would be interested in seeing what you could produce, but I would be afraid of the glare afterwards while driving.
Old Sep 2, 2010 | 12:32 AM
Engine: 383 stroker
I plan on trying to keep it kinda dim if i can
Old Sep 17, 2010 | 11:36 PM
Engine: 383 stroker
here is what i got so far after fiberglassing sanding bondoing an sanding,sanding, sanding, sanding and more sanding..lol
Old Sep 17, 2010 | 11:38 PM
Engine: 383 stroker
I still have to sand it all out and shape a few spots but hopefully i will be able to prime it next week.
Old Sep 22, 2010 | 04:27 PM
overide's Avatar
Agreed... Just a subtle color change to a lighter shade and you will be surprised what it will do to your visability. Just take different color towels and put them on your dash and notice the difference. And texture plays a large part. Smooth glossy dashes can blind you with a reflection or even make an odd glare on the windshield. For this I would also try getting something to lay on the dash and try it before going thru the effort of slicking anything out.
Some custome dashes are even made shorter so there is less to reflect in front of you. Give this some thought in your final paint and finish design
Old Sep 22, 2010 | 05:14 PM
Engine: 383 stroker
Thanks for the advice I am thinking about painting most the dash black or satin black so it shouldn't be to blinding by time im done.
Old Sep 22, 2010 | 05:16 PM
spade's Avatar
Car: 1989 Mystery Firebird
Engine: 350 FIRST TPI
cool idea
Old Sep 22, 2010 | 07:34 PM
irock88's Avatar
Car: 88 (SOLD) & 90 Iroc convertibles
Engine: 5.0 TPI, 5.0 TPI
Transmission: 5 speed & auto
Axle/Gears: 3.08 & 2.73
great idea I`ll bet it`ll look great once your done!
Old Sep 23, 2010 | 11:29 PM
Engine: 383 stroker
Here is some pics of my first test fit. Everything went in fine
Old Sep 23, 2010 | 11:31 PM
Engine: 383 stroker
Here is some after a few coats of primer and some wet sanding I still have alot left to do before I start painting.
Old Sep 23, 2010 | 11:49 PM
masonmills's Avatar
Car: 1985 Trans Am
Engine: 305 Carb
Axle/Gears: Borg Warner 3.27
im interested to see this.
subscribing
Old Sep 24, 2010 | 08:01 AM
overide's Avatar
Make sure you get a good sanding block to keep it easy to hit the high spots! what are you gonna do with the speaker holes?
Old Sep 24, 2010 | 06:16 PM
Engine: 383 stroker
I am going to put speaker grills over them, so that basically all you see is the new 4x6 I put in
Old Oct 1, 2010 | 08:33 PM
Engine: 383 stroker
Here is what I have done this week I finished all the prep and I laid the base coat of silver.
Old Oct 3, 2010 | 08:27 PM
TPI-RS's Avatar
Car: 1991 RS Hardtop
Axle/Gears: 3:23
Cool idea... interested in seeing what it looks like!
Old Oct 3, 2010 | 08:35 PM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Curious how this turns out. Mine is cracked all over and I cant find a good dash anywhere. Did you peel the plastic/leather off or how would you go about fixing the cracks and making it smooth?
Old Oct 3, 2010 | 08:53 PM
Engine: 383 stroker
I just filled the cracks with a bit of black scilicone calking then fiberglassed the whole dash. I think if you pilled off the vinyl it wouldnt look right when you fiberglassed.
Old Oct 3, 2010 | 09:13 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Good job!!
Decided what graphics to do??
Old Oct 3, 2010 | 11:25 PM
Slash's Avatar
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
I gonna have to agree with lasher, It would look cool, but i think the glare would become a problem, unless you bought a dash pad cover for driving and just showed the gfx at shows
Old Oct 4, 2010 | 12:38 AM
Engine: 383 stroker
Well I've named my car "Demon Speed'n" like the rob zombie song so I think I am going to air brush some skulls along the length of the dash. I know that it isnt everybody's taste but I have always had a thing for skulls. As for the glare I have concidered that and right now with the base coat of silver and the 2 coats of clear it is pretty shinny and I put the dash pad in like it is and drove around some and it wasnt that bad...Im also going to do a good majority of the pad in flat black so it shouldnt be that bad...if all else fails I can always put a towl over it when I drive...lol
Old Oct 6, 2010 | 11:38 PM
raptor91623's Avatar
Car: 1985 Camaro IROC
Engine: 350 tpi
AGREED!
Old Oct 7, 2010 | 10:24 AM
Camrs89's Avatar
Off the subject somewhat...but Im wondering if you can do this to fix the cracks and then cover it somehow or paint it with black wrinkle finish paint to kinda give it a somewhat stock look to it. I cant find a mint dash pad to save my life right now and the ones I find people want too much for them. Just looking for other options...
Old Oct 7, 2010 | 10:50 AM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Subscribed!
Old Oct 7, 2010 | 10:56 AM
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
Here is a link to a way you may like, and if you arent satisfied with the results u could always just wrap it in vinyl. This way in the link will seal the dash and make sure it wont crack again. Im gettin ready to do it this winter. http://gtam.silvahalo.com/dashrepair/
Old Oct 7, 2010 | 12:04 PM
overide's Avatar
Interesting... Thanks for the link. Sounds like a good repair. Especially if you take your time and be sure things are level and even before you spray. I wish the pics were a bit bigger so things could be read in the pic and seen a bit better. Oh and make sure you use the bed liner and NOT undercoating. The Undercoating never really cures right, you end up having to paint over it! I used a bunch of it when I was doing some sound proofing.
I debated about a vinyl wrap myself...
Old Oct 7, 2010 | 12:14 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
subscribed. interested in the finish product
Old Oct 8, 2010 | 07:35 PM
Engine: 383 stroker
I started air brushing this week but my air brush crapped out on me so Im waiting for a new one to come in ill try to post some pics soon, oh and if this turns out well I will be selling my original dash pad, its in good shape there are some damage mainly where the previous owner over tightened the bolts in the defrost area and caused some minor cracking
Old Oct 13, 2010 | 05:27 PM
Engine: 383 stroker
Ok finally got it in so here is what I got done today I still need to do some highlighting and touch up before I lay the candy coat. Oh and add some details to the skulls.
Old Oct 13, 2010 | 07:15 PM
racerquinny's Avatar
Car: 91' camaro rs and an 87' trans am
Engine: stang eater..slower ones. lolololol
Transmission: 700r4-camaro t5-trans am
Axle/Gears: stock :(
that looks amazing!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Oct 13, 2010 | 07:21 PM
rich5's Avatar
Car: 91 camaro RS
now thats freakin cool
Old Oct 14, 2010 | 12:19 AM
Blown84Bird's Avatar
Car: 84 firebird, 85 transam
Engine: 350 SBC Or 7.07 Tonys,305stock
Transmission: Big Ugly, 700r4
Axle/Gears: 4th gen rear disk 3.42 lsd,9 bolt
Looks good
Old Oct 14, 2010 | 01:45 AM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
why not mount speakers from the top, this way i sure you could easily fit some 6 1/2 and it would look better plus sound better
Old Oct 14, 2010 | 12:08 PM
overide's Avatar
Not a big skull fan myself buuuttt... but Dang you got some airbrushing talent and it looks awesome!
Old Oct 14, 2010 | 07:47 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
looks bad ***. Can't wait to see final product.
Old Oct 14, 2010 | 08:21 PM
joepackersrock's Avatar
Car: 1991 RS Camaro
Engine: 400 Smallblock
Thats gonna look pretty sweet, how long does it take to do all that air brushing?
Old Oct 14, 2010 | 08:42 PM
383 Power's Avatar
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
That looks just Great! However, i think it would look BETTER if you would Reverse the Color Theme. Make the Dash Black and the Skulls Grey.
Old Oct 14, 2010 | 09:34 PM
Engine: 383 stroker
Well so far I got about 4-6 hours into the airbrushing....the initial lay out of the skulls only took a couple hours...as for the final look if everything goes as planed
the skulls are going to be candy apple red and the rest of the dash will be flat black. Why it is silver and black right now is because when you lay candy red over silver it makes it pop more.
Old Oct 14, 2010 | 09:53 PM
Engine: 383 stroker
well I already installed new speakers and I have designed the dash the way im going so I think ill stick with it...thanks anyways for the idea.
GTA50's Avatar
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
That looks freakin' beautiful. Great airbush skills. So, are you carrying the theme through the interior and exterior?
Old Oct 14, 2010 | 09:57 PM
Shadow Z's Avatar
Car: Lots of 'em
Really nice job! I wish I would have seen this earlier, and been able to subscribe, but I just haven't had the time to get on TGO. Can't wait to see the finished product.
Old Oct 14, 2010 | 10:40 PM
  #42
Engine: 383 stroker
well I plan on in the future doing some more fiberglassing of parts center console t-top headliner etc so if it turns out alright then yeah I will do some more in the interior
Old Oct 23, 2010 | 04:00 PM
  #43
Engine: 383 stroker
Ok here is what I got done this week I highlighted the skulls, added some details, laid the candy apple red and and clear coated it.
Old Oct 23, 2010 | 04:02 PM
  #44
Engine: 383 stroker
The pictures may not do the color real justice It looks deep red almost crimson but with my camera flash it makes it look a little pinkish
Old Oct 23, 2010 | 06:41 PM
  #45
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Looks Awesome!
Old Oct 23, 2010 | 07:22 PM
  #46
BlackTopKing's Avatar
Axle/Gears: Posi 3:42
very cool idea and great work, you should check out my thread (last papes) hope it gives you some idea's to play off and make your own
Old Oct 23, 2010 | 09:19 PM
  #47
Engine: 383 stroker
Good job man I like where you went with your car I think Im gona keep most of my airbrushing in the interior and maybe under the hood, but I like your work.
Old Oct 24, 2010 | 10:29 PM
  #48
fdhoenix92's Avatar
So you had no problems with the fiberglass bonding to the vinyl top?
Old Oct 24, 2010 | 11:17 PM
  #49
Primetime91's Avatar
Car: '88 Camaro (Gone...)
That's sweet looking, nice! You've got some talent
I just hope the dash doesn't crack on you again... That would be terrible
Old Oct 24, 2010 | 11:26 PM
  #50
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
Originally Posted by Jason1313
Subscribed!
