A question about rear plastics.
Old Sep 10, 2010 | 11:48 PM
fgraves73's Avatar
Car: 85 Pontiac Firebird
Are there any differences in the rear plastics between the Camaro and Firebird? Are there any through the different years? My 85 FB needs everything from the rear seats back. I just want to make sure I'm looking in the right places for replacements.
Old Sep 13, 2010 | 07:19 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Re: A question about rear plastics.
'89-up had rear shoulder belts, so the side panels have cutouts for that. '86-up had a power-pull-down hatch release, the the very rear panel is shaped different to accommodate that. The rear folding door (optional, not very common) is also shaped different for the same reason.
Also, some have provisions for split folding rear seat and roll-up shade, while others don't.
Old Sep 14, 2010 | 02:45 PM
fgraves73's Avatar
Thanks 86blackiroc. That helps a lot.
Old Sep 15, 2010 | 07:52 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I came up with a couple other things that were different about the plastics too:
The 2 side hatch panels, and the one on the hatchback itself are made for cars with and without a roll up shade.
Some cars have an optional Light mounted in the hatch,..... earlier cars had an ON/OFF switch hole too. Later cars had the light hole - but no hole for the switch.
T-Top cars used a rear hatch panel with "Slits" in it for the T-Top bag straps.
Some cars needed a "contact pad" from the hatch to the body for wiring certain options. ( rear wiper, 3rd brake ) There would need to be a hole in the top of the rear hatch panel of those cars.
The headliner trim was completely flat in 82-89 cars, but 90-92 needed hardware mounted on it for the exterior third brake light.
Some 82-86 cars had a rear wiper motor that required a "deep" hatchback trim panel.
Non rear shoulder belt rear seat belt covers had slots in them for the rear seat belt to pass thru it..... Rear shoulder belt cars had no holes in that spot.
They are not different from make-to-make, but there are a bunch of options from year-to-year. There are a couple color changes too so try to stay close to your original year when picking plastic parts. ( example: the early red color was darker than the later red )
Old Oct 23, 2010 | 04:38 PM
fgraves73's Avatar
Thanks John. I appreciate all the info.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
