Oil pressure guage is non functional.
Old Sep 20, 2010 | 11:48 PM
Jonesy88's Avatar
Engine: 305 TBI
Transmission: 5 Speed manual
What r some things to look for or how do i go about testing parts on my 88 t/a to find out why my oil pressure guage is not working.
Old Sep 21, 2010 | 07:15 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Oil pressure guage is non functional.
the most common cause of not showing oil press. is the sensor . located just above oil filter . not very expensive , not too hard to change . be careful of old/brittle plastic on sensor . good luck .
Old Sep 21, 2010 | 02:07 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
thats the sensor for the fuel pump, what he wants is the oil pressure sender, it is screwed into the block behind the intake manifold towards the drivers side of the dizzy
Old Sep 22, 2010 | 12:48 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
On older models like yours, yes. On the 88 TBI it's where Uncle Tom described
Old Sep 22, 2010 | 03:26 PM
Chevy8588's Avatar
really.. thats funny, cuz the 305 TPI engine in my 85 was before the rebuild originally an L03 TBI that came out of my old rusted decrepit 88 RS. take a wild guess where it was? on top. the only sensor in the filter housing was for the fuel pump.
Old Sep 22, 2010 | 04:04 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Well, you can put one there. It's easier to get to and an easier place to connect a manual gauge for testing.
Old Sep 22, 2010 | 08:48 PM
Chevy8588's Avatar
im just stating that mine was there from the factory on my 88, and still is there on my 85
Old Sep 26, 2010 | 09:36 AM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
chevy, take his word for it. I changed mine too and it's right above the oil filter.
Old Sep 26, 2010 | 11:23 AM
Jonesy88's Avatar
Engine: 305 TBI
The sending unit was on the back of the intake and I replaced it and my oil pressure guage is workin now. Thanks for the info
Old Sep 26, 2010 | 11:47 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Some cars had them on the china wall, some had them above the oil filter, and some even had both - the cars with both had a seperate unit for the fuel pump and a seperate unit for the guage.
Old Oct 20, 2010 | 05:54 PM
Manovox's Avatar
Car: 89 RS Camaro
Engine: 350 ci
Axle/Gears: 3:42
I am having some problems the same!
I swapped to carb from tbi and removed the sending unit near oil filter and kept the one near distributor with 3 wires and screwed it near oil filter and blocked the other and gauge is not working!
I am with a mecahnical fuel pump so I need to know which wires to remove or use!
Old Oct 20, 2010 | 08:23 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Does anybody know where it would be on a 327
89GTAOz
May 16, 2020 09:31 AM
Prodigious
Oct 4, 2015 11:20 PM
solocus
Sep 2, 2015 12:14 PM
CamaroGuy350
Aug 30, 2015 02:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
