85 berlinetta 2.8l DASH!
Old Sep 26, 2010 | 06:08 PM
jtsherrod's Avatar
i need the digital dash or digital instrument cluster, whichever you wanna call it. I can't find one anywhere. Apparently they have to match your motor to so i need one the was with the 2.8l v6?
thanks for the help
Old Sep 27, 2010 | 09:42 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: 85 berlinetta 2.8l DASH!
Even though it is a digital dash, I'm willing to bet that the tach circuit is the same as the analog circuit, which means you could modify a V8 tach to work with a V6 with a simple resistor swap. The only other difference on an analog dash is the oil pressure range, but on the digital one it may be compatible, I'm not sure.
Old Sep 27, 2010 | 10:02 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
The oil pressure gauge is analog, and the tach is digital. If you put a V8 dash in, it will screw with the tach, but I'm unsure about playing with resistors. I have a V6 dash I believe from an 86 berlinetta with fuel injection if interested. Worked perfectly on my '84 with carb so it doesn't really matter which v6 you have it would appear. Click on my name on the left and send me a private message if interested, and I will get you a shipping quote if you give me your zip.
Old Sep 29, 2010 | 06:36 PM
jtsherrod's Avatar
hey man i am def. interested in the v6 dash!! but i cant figure out how to send u a private message?? i tried the AIM but it doesnt work? you can e-mail me at soccersherrod86@yahoo.com if you still have that dash ... thanks!!
james
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Fanatic1074
Oct 2, 2015 03:47 PM
Linson
Oct 1, 2015 09:50 PM
lewandom
Oct 1, 2015 08:15 AM
rusty vango
Sep 29, 2015 02:44 PM
