Dash Guages
Old Oct 13, 2010 | 12:19 AM
donnas88camaro's Avatar
Car: 1988 Camaro
Engine: 2.8
Transmission: auto
Dash Guages
I notice that the guages on my dash are off. The tech pins itself when you take off, also the oil presure guage is also pinned up when you start the engine. The speedometer is off by 10 mph.
Could this be a bad ground or are the guages just bad? Thank you
Old Oct 13, 2010 | 01:47 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Re: Dash Guages
the speedo is calibrated for 25.7 inch tall tires.
the gauges weren't all that accurate to begin with, and pretty common to be screwy these days. If you google "tachman" you'll find a company that calibrates gauges, but I bet its expensive.
There's also a thread on replacing resistors in the circuit board yourself, but I personally didn't have much luck with that.
Old Oct 13, 2010 | 11:18 AM
Car: 1988 Camaro
Engine: 2.8
Transmission: auto
Re: Dash Guages
Thank you, will look it up and give it a shot..
Old Oct 13, 2010 | 12:52 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Dash Guages
I know grounded sensor wires for some gauges peg the needles, but don't know if that applies to the tach as well. Worth checking for sure. Sent PM for another option if interested
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
