Temp and fuel guage problems
Old Oct 17, 2010 | 08:13 PM
91camarolover's Avatar
Car: 91 RS, 84 Z28, 85 Iroc-z
Engine: 3.1L, 350 4 bolt, 350 TPI
Transmission: 700R4, 700R4, 700R4
Axle/Gears: 3.23, Unknown, Unknown posi
My temputure guage never moves it just sits at 100 degrees and then my fuel guage is pegged all the way up... any help would be awesome thanks
Old Oct 18, 2010 | 07:49 PM
SpiltTransFluid's Avatar
Car: '84 sport coupe
Engine: 355 .030 over 202 heads cam from RV
Axle/Gears: Idk, re is out of 93-97 V8
Re: Temp and fuel guage problems
Check your sender on the side of the block for the temperature. Its just behind and below the number 1 exhaust port your connector could have slipped off. As far as the fuel gauge you might have a short in that wire somewhere
Old Oct 20, 2010 | 09:54 AM
Mrs.Crasher0083's Avatar
Car: 88 Pontiac GTA and 4 Camaros
Engine: 5.7
You might want to check and make sure the gauge cluster isnt loose. I had that problem and my husband fixed it by simply pushing the cluster in. Maybe it came loose when ya hit a bump or something? Theres 2 plugs behind the cluster... if your not getting a good connection it would do something like your describing. Hope its that simple and it helps ya out. Goodluck
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
92camaroJoe
Aug 13, 2015 06:07 AM
