Driver Side window wont roll down
Old Oct 26, 2010 | 01:48 PM
dominicparker92's Avatar
Car: 92 Rs Camaro
Engine: 3.1lt
Last Night i parked at a gas station rolled my window up got back in and the window wouldn't roll down. It was working perfectly until then. Is there any way to tell if its the switch or the motor?
PLEASE HELP!
Old Oct 26, 2010 | 07:04 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Driver Side window wont roll down
Swap the switches & see if the problem persists.
Old Oct 26, 2010 | 09:12 PM
Sandslot's Avatar
Car: 1987 IROC-Z Z28 Convertible
Engine: LB9
Typically if one window works and the other not, as mentioned already, swap switches. In my expierences, the wires may have fallen off the switch (especially if removed several times and have broken tabs). Second, check the connection at the motor in the door.
evan555222
Sep 20, 2016 02:51 AM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
pfsteichen
Feb 9, 2016 06:59 PM
evan555222
Aug 22, 2015 07:14 PM
timonator
Aug 11, 2015 09:56 PM
