how to retract/remove seat belt from headliner
Old Oct 28, 2010 | 09:22 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
About a week ago, while putting on the driver's side seat belt, about 5 seconds after I engaged it, I heard a small pop and the seat belt came loose from the headliner retactor.
My headliner is mint and I have been trying to figure out to take it out without removing the headliner since my headliner is mint and original.
I found this thread but there any other way to fix the retractor without removing/damaging the headliner?
https://www.thirdgen.org/forums/inte...retractor.html
Thanks!
Old Oct 28, 2010 | 09:35 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: how to retract/remove seat belt from headliner
There is a split in the headliner - you pull the belt out through the slit as you are dropping the headliner. The split is covered by a plastic cover that snaps into the seatbelt retractor - so you unsnap the plastic cover, remove the headliner pulling belt out through headliner slit, then remove the retractor. Plan on ordering A-Pillar clips from dealer, get a bag for $20 - the A-pillar clips always break.
Old Oct 29, 2010 | 08:37 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Drop the headliner. If you don't, you risk damaging it while messing with the seat belt. Be careful with the headliner handling and you'll be fine. There is a slit in the headliner right at the seat belt retractor. You can also get the clips mentioned for the A pillar at most auto parts store in the Help! section for considerably less than dealer pricing. Shortcuts usually cost more in the end!!
Old Oct 30, 2010 | 07:59 PM
topduarte's Avatar
Transmission: auto
Thanks guys!!
That looks like my Sunday Project.
ZMWojnar
Interior Parts Wanted
Sep 24, 2015 08:34 PM
scottmoyer
Sep 20, 2015 11:54 AM
MORREALE5
Sep 13, 2015 09:01 PM
iroczguy86
Sep 13, 2015 02:22 PM
MORREALE5
Sep 10, 2015 08:58 AM
