91 LED dash lights are they bright?
Old Nov 17, 2010 | 09:04 PM
chevysurfer's Avatar
Car: 91 CAMARO RS
Engine: 305 TBI
Transmission: AUTOMATIC
Im a little confused, I have read the threads and the older camaros with the guage pods seem to look good but the 91-92 guages I was reading that they were not bright? My understanding with LED is that if you have translusant red plastic you would use a red LED and so on with the different colors, unless the plastic is clear than any LED will shine thru. I know that LED lights arent as bright as regular bulbs, but the color is better, run cooler, last longer, less energy, and the new h/o bulbs put out equal amount of lighting but at a hefty price 8-12$ a bulb. My concern is the 91 instrument cluster lettering is a yellowish color and from what I have read theres only 4 illuminating bulbs. I have my dash and cluster out right now and I see some black and grey plugs that are the same size but theres more than 4 of both colors so what the deal with that. Any other mods like the white over lays, are can you pull the hole cover off and replace with custom ones.
fonzie85
Aug 13, 2015 11:50 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
