Convert Speedometer for Tranny Swap
Old Nov 22, 2010 | 02:20 PM
rockstarr4's Avatar
Car: '84 Camaro - 2010 Surf Blue
Engine: 305 - 4 bbl Holley
Transmission: WC T5
Axle/Gears: 3.08
I'm about to swap my ailing 700R4 for a T-5 in my 84 Camaro. I've been told that the T-5 (91 Firebird vintage) has an electronic speedometer sending unit, but my 84 has a mechanical speedometer. How do I convert this? I can't use the speedo out of the Firebird as the instrument cluster is different. What's my best option going forward?
Old Nov 22, 2010 | 02:47 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Convert Speedometer for Tranny Swap
Remove the VSS from the tail shaft of the 91. Purchase the correct speedo gear housing and drive and/or driven gears for a T-5 and swap in. Screw the cable in place.
http://www.transmissioncenter.net/sp...____va.htm#350
The link below may be helpful as well:
https://www.thirdgen.org/forums/tran...ve-driven.html
JamesC
Old Nov 22, 2010 | 10:29 PM
rockstarr4's Avatar
Transmission: WC T5
Axle/Gears: 3.08
Thanks for the advice, it looks like it won't be too much of a problem.
Old Nov 23, 2010 | 07:39 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It's a piece of cake. Since that T5 was used in applications with mechanical speedos as well as with electric, the mechanical & electric senders are interchangable in the tailshaft. You just need to get one from a car with a mechanical speedo and install it in your T5.
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
gta90
Sep 15, 2015 04:00 PM
spaigo
Aug 21, 2015 07:46 PM
