HOW TO remove/install bottom of console
92 Z28 convert
long story but center console was completely out and I am now trying to put one in - I cannot get bottom section it to clear the shifter and ebrake handle so it will fit correctly - looks to me like I need to somehow remove or release the ebrake handle so the cross bracket on the lower console will be able to fit down in front of it - does that sound right?
I searched on here but cannot find any detailed info on the removal or installation of the console lower part - if I do need to remove or release the ebrake hadle to a certain position is there an easy way to do it short of removeing or disconnecting everything?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: HOW TO remove/install bottom of console
Need to really lift the E brake almost straight up - use both hands and pull it way up - then slip front of console in holding rear up, then work rear of console down over the E-brake. Also helps to put auto shifter into D or 2 (chock wheels).
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I 2nd that as i have never had to unbolt the e-brake at all and Ive do it tons of time to my car. It can be a pain at times but it will go
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Yes,As above.It can be painful but it can be done.Just be careful with the thin areas of the console,so you dont break them.
MrPackstin
Oct 25, 2017 08:09 PM
