Filler Panel Clips
Old Dec 8, 2010 | 10:32 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Filler Panel Clips
What are the clips & screws I need to hold this up with? I just bought filler panels for underneath my camaro dash (covers up all wires, fuse box and passenger side). I Just want to know what screws, clips, etc i need to buy to install this. Plus a good site to buy new insulation for this as well.
Old Dec 9, 2010 | 01:36 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Filler Panel Clips
I think you are talkin about the "hush panel".
It uses ordinary self tapping screws. Just place it in position and you will note the screw holes already in the panel. They should line up with existing holes in the bottom of the dash and other in place structure.
Insert new screws in the holes. Most are friction fit and don't require backing clips unless the existing holes are stripped out.
NO insulation needed..........My 84 hush panels didn't have any.
EASY fix!
Old Dec 9, 2010 | 06:16 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
http://thirdgenranch.com/-strse-808/...ash/Detail.bok
Oh i got mine from thirdgenranch, and i got it for my camaro; they didnt come with screws; but what type of screws? the stock ones around other trim (example: under steering wheel column)
Plus mine had some foam on it.
Night rider327
Feb 25, 2016 09:50 AM
86IROC112
Nov 7, 2015 06:50 AM
kkirch15
Sep 30, 2015 04:44 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
formula00ra
Sep 28, 2015 11:50 AM
