interior plastic paint
Old Dec 19, 2010 | 03:46 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Transmission: auto & t5
some of my interior plastic peices were broken nut i had extra ones in red and grey. so i painted them black with the dupli-color vinyl & fabric paint. i used this on my new seats out of a 2002 ss camaro that were pewter color and it worked great .so i thought sence the can said it works on dashboards and doorpanels i could paint my plastics also. it looks great but i was wondering if anybody else has painted their plastics ? should i put a clear coat over them to protect them? i think it might give it that just armorall look . any suggestions would be much apprecited.
thanks
bruce
Old Dec 19, 2010 | 06:15 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Re: interior plastic paint
Most people use SEM dye, not paint for plastics...
Though I've not done a test of the paint you've mentioned...
I've heard of some people "painting" the plastics and it coming off in sheets.... ??
try a bad piece and play around with it...
Either way, be sure to get it clean, TSP(tri sodium phosphate) is good and heavy duty...
Rafael
Old Dec 20, 2010 | 06:39 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
if you're looking just to do black, krylon fusion works really well and readily available. meant just for plastic and i've never had it run or chip (can't say the same for some of my other paint/touch up attempts....)
Old Dec 20, 2010 | 05:44 PM
usacamaro's Avatar
Car: 92 rs & 89rs
did you use a clear over the krylon?
Old Dec 21, 2010 | 07:28 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
no clear, not a fan of super shiny plastics myself, but they do offer a clear coat for those who do. its got a semi-gloss finish to it when it dries
Old Dec 21, 2010 | 07:38 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
The SEM dye will give you a finish that is closer to the original look but the Krylon is decent. Prep with TSP is key!
No need to clear coat.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Exxon Limited
Aug 9, 2015 08:13 PM
