Camaro/Firebird Locking Ignition Problems
Old Jan 3, 2011 | 07:42 PM
travisgold's Avatar
Car: 1984 Camaro Z28
If you have locking ignition problems here is a quick easy and inexpensive fix!
All you need to have is WD-40 Spray it inside your ignition try switching it to lock position let it sit a few seconds they spray some on your ignition key Try Turning the key if it doesn't turn while holding the key in press down on the key slightly then try turning the lock cylinder it should turn if not try some more WD -40 let it sit then try again same method if it doesn't work then try moving the key up and down but holding in that position you move it then it should work if not you may have a broken or damaged ignition cylinder then you will be again in no time!
BRoss99
Aug 10, 2025 05:08 PM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 18, 2015 02:28 PM
Zachattack0925
Aug 12, 2015 09:52 PM
