Adding Power Windows??
Old Jan 15, 2011 | 04:03 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
Hey my 87 camaro has standard hand windows I was interested into installing power windows. Is there any way they make kits for them or if I can take them out od another camaro and put them into mine...thanks!
Old Jan 15, 2011 | 05:45 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Adding Power Windows??
I'd think it would be easiest to get a pair of powered doors and swap. You could get power mirrors & windows, and install new hinge kits before/during the swap, and have great doors afterwards - of course that means paint though.
You could get power window regulators and motors and swap them in from a JY car - I'd install new motors regardless.
Old Jan 15, 2011 | 06:01 PM
calgutie's Avatar
Car: 1984 Z28
ooooohhhh okay thanks for the info
Old Jan 15, 2011 | 06:33 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i know of 1 company that makes aftermarket kits . no need to remove old linkage/door because you use it . " SPAL " , my car had their kit installed when i bought it . it's simple compared to swapping parts from a donor car . i have owned 3 third gens and 2 3rd gen parts cars . so this is not my first rodeo . much easier to use their kit . check them out , just punch in SPAL on your search . good luck .
Old Jan 15, 2011 | 08:06 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
You know, I'd really recommend staying with your manual windows... The power windows in these cars perform so poorly that manual windows are about 10000x faster. If I could remove mine and go to crank conveniently, I would.
Old Jan 16, 2011 | 12:46 AM
Krik's Avatar
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
Axle/Gears: G92 3.23
There are many cars being parted out on these boards, or at the salvage yards. You could find the parts you need that way.
Its going to make your car heavier/slower though. (Can you tell I am biased?)
Old Jan 16, 2011 | 06:51 AM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
I swapped from my old car. The wiring harness gets power from junction block behind left kick panel maybe above it a little IIRC. Ground is under console. Not that hard to do.
Dante, I've got my old regulators and console top if you want them. Regulators worked good. Console top may be rough around ash tray.
Old Jan 18, 2011 | 11:50 AM
mudd746's Avatar
Car: 89 IROC Convertible
Engine: 305HO
A1 electric sells power window kits i just did mine a couple weeks ago direct bolt on replacement of factory regulator for about 290 bucks with wiring and switches
Old Jan 18, 2011 | 12:13 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
thirdgen ranch has a kit for adding power windows and power locks for under $100. Its used, but its all stock parts, wiring, switches, etc. Almost went that route when I was working on the dash swap, maybe when the car's running again
Old Jan 18, 2011 | 03:13 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
This link has everything you need to know (and more) including pictures. I printed it and got the used stuff from 3rd gen ranch.
www.p71interceptor.com/thirdgen/powerwindows
Swap "powerlocks" for "powerwindows" for even more info.!
Old Aug 8, 2011 | 05:53 AM
escalations's Avatar
Car: 1982 Z28/1986 Iroc-Z28/2005 Sierra
Engine: 355/LG4/L33
Transmission: SuperT10/T-5/4L60E
Axle/Gears: 3.73:1/3.73:1/3.73:1
"This account has been suspended" is what shows up when I try the link. I'm looking at picking up a new camaro project and it's got no power options so I was looking for info and this link keeps coming up in all the threads I've searched, BUT it fails. Does anyone have a copy of the info or know who hosts the page and if they could fix whatever is wrong. REALLY would love this info as it would make life a LOT easier...thanks
Old Aug 8, 2011 | 10:35 AM
mudd746's Avatar
Engine: 305HO
http://www.a1electric.com/ is where i got mine
Old Aug 9, 2011 | 01:27 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
"This account has been suspended" ...
Turns out the guy who hosted the site died. It's primarily a Crown Vic site but has a third gen section with some useful stuff like the power window and door lock swap. Someone mirrored the site so try this:
http://www.idmsvcs.com/2vmod/thirdgen/index.html
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
