What tool do you use on seats
Old Jan 27, 2011 | 04:39 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
what tool do you use to take the release button that makes the seat fold forward.beings were in the seat category.I didn't know how to remove the headrest either thanks for asking.
Old Jan 28, 2011 | 12:53 AM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: What tool do you use on seats
Do you have some special button or is it the same small lever on the seat back thats in Camaros? If so then that lever is built into the hinge assembly. I was just looking into that a while back because my levers are broke so I had a couple spare hinge assemblies. But the lever also does not come into use unless the seat if at a foward angle like when parked on a hill.
As for the head rest, there is a tool but I have used a Slim Jim (not the snack food).
Slide it down in the front and it will go between the head rest bar and the tab that lock it in place, then pull up on the head rest.
Old Jan 28, 2011 | 07:17 AM
torque_is_good's Avatar
I reupholstered my seats. I used a feeler gauge. lift the headrest up a little, slide the feeler guage down the middle front and continue to pull up the headrest......voila!!
Old Jan 28, 2011 | 09:05 AM
mantaguy's Avatar
Engine: 5.0 EFI
Hey Mad,I got a small black lever type button that you have to move up to push the back of the seat forward,it has a very small hole in it,looks like some kind of tool you use to remove the thing,I want to remove the upholstery but that is in the way.
Got the headrest out,used a flimsy metal ruler with a rounded edge,worked pretty good .
Old Jan 28, 2011 | 06:07 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
I can't imagine what the birds look like. My Camaro the lever is part of the latch which unbolts from the side of the seat back and seat bottom. The plastic panel comes off because its notched for the lever to come out of.
tyeo098
Nov 30, 2015 06:27 PM
GageBrand
Oct 22, 2015 02:30 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
kitt23
Sep 26, 2015 07:48 PM
mrdevontay
Sep 2, 2015 08:04 PM
