headliner questions
Old Feb 12, 2011 | 10:39 AM
WESTOF7's Avatar
headliner questions
I've got a 86 z28 30000 miles the headliner got wet and the foam deteriorated around the back edge of the t top from water damage.
I ripped the damaged foam out now theres a 2x8 section missing from the edge. whats the best way to fix this? fiberglass? and to reinforce the back should I just use resin or glass It too? Is there a specific type of fiberglass I should use? will 3m spray adhesive work or should I be using something else? Dont want the glue seeping through the fabric. yes I searched and read every thread that came up.
Old Feb 12, 2011 | 11:00 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: headliner questions
On the rest, not sure of your best course of action - but on the fabric glue, use headliner glue available at auto parts stores - it sticks best.
Old Feb 12, 2011 | 11:05 AM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
When going through the trouble of taking the headliner out (just pulled mine about half an hour ago ) I would not take any half assed atempts to fix it "for now".
One route would be to order a new headliner.
Once it´s out check whether or not your weatherstripping is ok, and how the sheet metal is. I heard T-tops can show quite a bit of corrosion underneath the headliner. Be prepared for more work then you expected.
The other alternative is to fix and improve the current headliner once and for all.
Fiberglass definately would be te way to go about a long time fix.
Since fiberglass is not expensive consider covering the complete headliner in fiber. The regular randomly weaved type will do fine. One layer will suffise.
Roll the resin onto your cleaned headliner (I choose to cover the inside, not the side touching the roof area) giving it a good solid coat of resin, then lay your fiberglass on it, cut away any edges and roll another layer of resin ont the headliner.
Let it dry for a few days. Then sand the fiberglassed area. I will then use a filler to smooth the complete headliner, then glue fabric against it.
Normal spray on glue will not hold. The car roof will get quite hot during summer. Most types of glue will dissolve and/or lose adhesion. There are special glues for this application, and I would advise to use them.
Once the headliner is off, check the T-top area and fix any corrosion/prevent corrosion by coating the headliner area.
Old Feb 12, 2011 | 12:09 PM
WESTOF7's Avatar
Im gonna try to just fix the one spot at this time the headliners perfect with the exception of that one area as the cars mint its spent its life in a heated garage and low miles Im only the second owner. no rust. Is there a particular brand of headliner glue and is there anything I should know about applying it? can I use two way tape in place of the two clips on the front of the board?
Old Feb 13, 2011 | 05:51 AM
92camaroracer's Avatar
Car: 91 z28
Engine: 383
Transmission: t-5
... might as well replace the whole thing with an ABS headliner from Hawks and for ~180.00 and piece of mind knowing it will last forever...its worth it IMO, but thats just my
Old Feb 13, 2011 | 10:36 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Subscribed for info.
Can't buy new. Shipping costs to "The Great White North" are HUGE.
Old Feb 13, 2011 | 11:08 AM
WESTOF7's Avatar
yeah I'm up here too getting parts shipped from places like hawks would be ridiculous. and honestly I'd make my own out of fiberglass before I paid that much for a headliner. Would two way tape work In place of the clips up front or maybe velcro ?
Old Feb 13, 2011 | 11:58 AM
Car: 89 IROC
^^ I've heard of people using both with success.
There is a guy on ccfbg who fibreglassed his t-top headliner (he reinforced the edges) and recovered it with suede. It seems to be working fine.
I'm trying to figure out which glue to use. Another spring project.
Where are you located?
Old Feb 14, 2011 | 04:03 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
got any photos of the new headliner?
Old Feb 14, 2011 | 07:12 PM
WESTOF7's Avatar
lm in winnipeg. and ill post before and after pics when I do it this weekend
Old Feb 14, 2011 | 07:17 PM
WESTOF7's Avatar
Im in winnipeg. and ill take pics this weekend
Old Feb 14, 2011 | 07:40 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
I got a used head liner that was in good shape.
I took off the cloth material & resi & glassed the upper portion that goes towards the roof. In spring, I'll do the side that gets covered like
the solitaire
suggests-- sounds like it'll last forever!
I went to the parts store, got a can of resin & a package of glass weave, & did the deed. My only draw back is the area for the sun visors needs to be done since the original material came off when I was taking it off!
Take your time peeling & scraping!! It will pay off in the long run!!
Old Feb 14, 2011 | 07:53 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
you can also buy a fiberglass version that appears to be better than the abs for 125.00 + shipping from marks custom fiberglass
Old Feb 14, 2011 | 08:01 PM
KITT1983's Avatar
I like KIDDs headliner better
Old Feb 15, 2011 | 10:46 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
I found a t top headliner at the junkyard that was broken up in a couple spots and I put resin on the whole back of it and put it back together and it worked great. I used regular spray adhesive to stick the finish mat on the outside. It's just a type of foam finish mat with a gray liner on the outside that matches the interior grey almost perfectly.
I have some pictures of it somewhere but I'd have to dig them up.
Old Feb 16, 2011 | 07:30 AM
WESTOF7's Avatar
would covering the back in resin be a good idea? any drawbacks to doing that?
Old Feb 16, 2011 | 09:45 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
no real drawbacks i can think of. resin will harden the fiberboard and make it a bit more water resistant. i would use a layer of fiberglass cloth (not mat - too stiff) to add a little more strength to what you have too. very flexible and good at contouring to different angles easily. i would only do it if you've stripped off the old cloth, as you could get some bleed through and ruin the material
Old Feb 16, 2011 | 12:28 PM
Car: 89 IROC
Any glue/adhesive suggestions?
Old Feb 16, 2011 | 01:30 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
3m does a great job with their adhesives, highly recommend their headliner spray. a bit more expensive than the generics, but well worth it from what i've done. Used it quite a bit when i was carpeting speaker boxes too and it held up perfectly
Frozer!!!
Jan 19, 2024 04:55 PM
Victor6
Aug 30, 2015 02:09 AM
Golfvette
Aug 24, 2015 06:35 PM
redmaroz
Aug 16, 2015 11:40 PM
TheJoeY88
Aug 13, 2015 06:51 PM
