Power Window Help
Old Feb 17, 2011 | 01:12 AM
valicswarrior's Avatar
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
Power Window Help
So i messed up when doing my window motor and did it the hard way with removing the the entire assembly got it all together again finally but not sure how the tension spring is installed properly at this point when the window is up there is no tension on it so when u shut the door it just pops off the regulator what did i do wrong?
Old Feb 17, 2011 | 03:52 PM
haroanarchist's Avatar
Car: 87 formula
Engine: LG4
Re: Power Window Help
If you could post pictures i may be able to help.
did you take the spring off the actuator why?
Or possibly did you put it together the easy way?
When you are putting the motor on the actuator you have to preload the spring.
with the spring preloaded you install the motor.
Be careful I came close to missing a tooth when I slipped.
I recommend some balling wire to hold the tension in place while you install the motor.
Old Feb 17, 2011 | 04:38 PM
Well the spring popped off when the motor was being changed i see the easier way of doing it now but little late for that. So basically i have the entire door put back together and did the spring wrong so is there a secret to putting it on without taking the motor back out?
Old Feb 17, 2011 | 10:03 PM
Car: 87 formula
Engine: LG4
Curse a lot cause your gonna have to take it out.
I'm cursing cause i just typed all this and my pc f***ed up.
Ok take it all back out
If your not strong then get some help
take the motor off
if you have a vice put the side the motor attaches to in the vice
if no vice bolt it down to a bench or block of wood
now turn the other half once to put tension on it
it should be pretty stiff (pun intended im a funny guy i think)
Now you should have something ready to hold it in place (i used balling wire)
take it out the vice or unbolt it
put motor back on
now go plug the motor in and run it up and down a few time to make sure it is working nicely
then have fun installing the damn thing
Old Feb 17, 2011 | 10:06 PM
Car: 87 formula
Engine: LG4
If you need to change motors again.
you can leave the regulator in the door and just drill thru to get to the motor rivets.
let that motor drop out then you will have to use bolts to put the new one back in.
It will be way easier then taking that sh*t out again.
What are you using to put it all back together bolts or rivets?
Did you ever find out how to tell what gears you got?
I got to change my gas tank tomorrow good thing i had a parts car i tell you wow its difficult to get one out. To bad you didn't live close i would do your window for you if you dropped my rear end and put my new tank in.
Old Feb 17, 2011 | 10:12 PM
86cam3ro's Avatar
Car: 86 chevy camaro
Engine: 350 horse 350
Axle/Gears: 4/11
hey guys i know this doesnt have anything to do with this add but i can not post my own damn post. i mean i dont know how! can someone help me???
Old Feb 17, 2011 | 11:24 PM
lol enjoy the drop i cut a hatch hole in the rear above the tank for the fuel pump replacement yeah i see now the easier way of changing the motor by drilling and i had to bolt it all back in didn't have big enough rivets oh and no i dont know that gears i have unless they are factory cuz i did my rpo and it came back 3.08
Old Feb 19, 2011 | 08:04 PM
Car: 87 formula
Engine: LG4
Yea I used bolts don't wanna drill out rivets again any way.
If you use those washers with the teeth on them it is easier to get them real tight since you don't have to hold both sides.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
