Screws?
Old Mar 18, 2011 | 10:45 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
Screws?
I took the entire interior out of my camaro a couple months ago and some of the screws and things lost their place, and I'm just now getting around to putting EVERYTHING back in, so I'll probably ask multiple times in this thread, thanks in advance!
Can somebody post a pic of what the screw looks like that goes into the upper sail panel area? Not the sail panel itself, but the plastic part?
Old Mar 18, 2011 | 11:19 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Screws?
You mean the screw that goes through the coat hook and holds the sail panel in place?
Old Mar 19, 2011 | 08:55 AM
chevydrvr's Avatar
Re: Screws?
NO I mean the screw that's higher up and goes into the plastic part. If you are looking at the driver side sail panel it would be up and to the left a little bit. There is one on each side of the headliner trim piece.
I'm not sure if it differs between years though.
Old Mar 19, 2011 | 09:10 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Screws?
short phillips head.
Old Mar 19, 2011 | 04:01 PM
chevydrvr's Avatar
Re: Screws?
How long or short would you say the screw is? Half an inch? 3/4?
Old Mar 20, 2011 | 12:52 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: Screws?
Find the smallest philips you got Half inch or less and those are them. Ive taken apart and put back together soooooo many interiors I know them all know LOL
Old Mar 20, 2011 | 09:48 AM
chevydrvr's Avatar
Re: Screws?
I tried the smallest phillips head, and it wouldn't work! It seemed like it wasn't long enough, but i'll give it another try.
Old Mar 21, 2011 | 04:09 AM
6SIX6's Avatar
Car: 89 IROC
Re: Screws?
Go up 1 size then as I thought it was the half inch ones as there isnt much room behind there for a long screw to go in
Old Mar 21, 2011 | 05:32 AM
chevydrvr's Avatar
Re: Screws?
I put in a crew that was about an inch long and that worked...thanks!
Old Mar 23, 2011 | 04:44 PM
chevydrvr's Avatar
Re: Screws?
Now I need to know what screws are used to hold the triangular trim piece that covers the wires for the 3rd brake light (1992 camaro keep in mind)
Old Mar 23, 2011 | 05:51 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Screws?
Two black round head phillips screws about an inch long
Old Mar 23, 2011 | 09:51 PM
6SIX6's Avatar
Car: 89 IROC
Re: Screws?
Yep they will almost be the same if not the same ones you used on the last piece
Old Mar 23, 2011 | 09:55 PM
chevydrvr's Avatar
Re: Screws?
Thanks again, I got it!
3rd gen money
Oct 11, 2019 09:57 PM
RedLeader289
May 28, 2019 01:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
Bigold4x4
Sep 28, 2015 05:21 PM
