B&m shifter wiring, help needed please
Old Mar 23, 2011 | 09:55 AM
rich5's Avatar
Car: 91 camaro RS
im a little confused with the wiring for the megashifter.
Basically i have three questions
1. should i have power to more than the dark blue wire?
2. with the two switches, it dosent say where or which prongs i should attatch to first. i assumed the lower prongs go to dark blue? the directions say different then the schematic?
3. in the circled area of the schematic do i take a new wire from saftey swith to a2/1 on the relay then ground a1/0 or what?
your help is much apperciaated
rich
Old Mar 23, 2011 | 09:01 PM
rich5's Avatar
Car: 91 camaro RS
Re: B&m shifter wiring, help needed please
anybody?
Old Mar 23, 2011 | 09:12 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
1. I'm not sure about that one.
2. As far as the switches go, it doesn't matter which prong is connected to which wire, as long as the second wire on each switch goes to where it should.
3. Yes, you take a new wire from one of the switches to the coil on the relay ( in this case, that would be A2) and then another new wire from the other end of the coil (A1) to ground.
Old Mar 24, 2011 | 05:14 AM
Twin_Turbo's Avatar
Not related to this topic but please check your PMs
Old Mar 29, 2011 | 10:07 AM
pimpimusmaximus's Avatar
Car: 1984 Z28 T-TOP
Engine: 355 Lt1 w/Hotcam
Transmission: TH700R4
Axle/Gears: 3.73 4th gen limited slip
Quick question, did the B&M shifter come with a shift plate? The plate that says P, R, OD, D, 3, 2, 1.
Old Mar 29, 2011 | 01:44 PM
chevydrvr's Avatar
Yes it does come with a shift plate, but you must have the original shift plate from the car to mount it to. You cut out a hole in the original plate and then screw the included plate down on top of that.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZ1989
Jan 24, 2016 03:55 PM
NBrehm
Aug 25, 2015 11:49 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
