91 camaro z28 cluster problems
Old Apr 4, 2011 | 08:25 PM
Bighawk's Avatar
Car: 91 Camaro Z28
Engine: 5.7L
ok so a few months ago the right half of my cluster stopped working. the right side has the tach heat and battery gauges. well a few days ago it started working again. all of the gauges worked fine except the tach, it was high a few thousand rpms and everytime i cut off the car it stayed at 2500 or so rpms. a mechanic told me i could take of the glass and mannually move the gauge needle to zero and it would work right. i tried that and now the whole right side is dead again. anyone know how to fix it or any suggestions?
Old Apr 5, 2011 | 09:12 PM
zeroesenz's Avatar
Re: 91 camaro z28 cluster problems
must be a bad week cause ...this morning i was driving to work tried to put on my cruise control and all of my cluster went dead speedometer stayed at 65 rpm went dead so did everything else ...oh btw i'm new to camaros so im freaking out !!!
Old Apr 5, 2011 | 09:31 PM
Bighawk's Avatar
Car: 91 Camaro Z28
Engine: 5.7L
ive had this one for a few months and its awsome but its still an old car so guess it comes with the territory. also when i put everything back together there are 2 long screws that i cant find where they go. so anyone with advice on that?
Old Apr 5, 2011 | 10:10 PM
flow305's Avatar
Car: 92 Camaro Z28 / 07 Subaru WRX
Engine: GM RamJet 350
Try taking out the entire cluster and re-install it. These are done electronically so just press it in firmly and it should start working again. I have removed mine a few times and even put white face gauges in it so I know if the cluster doesn't go in tightly some parts may not work. I remember driving in my apartment complex back in college 10 years ago pushing the cluster in while moving very slowly trying to get all the gauges to work. They all eventually clicked on and I have not had a problem since.
Old Apr 6, 2011 | 06:03 PM
Bighawk's Avatar
Car: 91 Camaro Z28
Engine: 5.7L
ok ill try it and see if thats the problem
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
tnrednneck
Aug 13, 2015 08:57 AM
ChevyZ71
Aug 13, 2015 07:30 AM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
