HELP: door panel bolt-hole stripped
Old Apr 23, 2011 | 05:14 PM
gta90's Avatar
Car: 1990 GTA (T-Top)
Engine: 305 TPI (LB9) / 115k miles
Transmission: 4L60 (MD8 non-E)
Axle/Gears: 2.73 (GU2) 28 spline POSI (G80)
I recently restored my interior door panels and when I put everything back together, I noticed that the arm rest upper section won't secure well. Upon closer examination I concluded that the bolt hole on the door panel is stripped, so the bolt that secures the arm rest upper section isn't biting securely.
I've circled the stripped part in the attached picture.
What is the best way to go about fixing this (ie: minimal effort with stock appearance and function)?
If the part needs to be replaced, then how do I remove the existing one and how do I secure a new one? It looks like that piece is riveted on. Also, what is the part called/part# (the part is circled in the picture)? Who sells it?
Attached Thumbnails HELP: door panel bolt-hole stripped-door_panel.jpg
Last edited by gta90; Apr 23, 2011 at 05:16 PM. Reason: attached picture didn't show up... reattaching
Old Apr 23, 2011 | 05:51 PM
campin1983's Avatar
Car: 1984 Camaro 'Vert
Re: HELP: door panel bolt-hole stripped
Most of the time those GM rivets can be drilled out. Then when you put the new part on, just use small bolts and nuts. As far as the part itself, not sure what it's called, but it should be easy to get from a junkyard. Could probably also weld a bolt to the back of the broken part, but that might be more effort than simply replacing it.
Old Apr 23, 2011 | 06:29 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If your arm rest have a bolt hole plastic cover, you could grab any screw from hardware store one size larger and use it (since the cover will hide it). Otherwise, might try Home Depot or something and see if they have a similar style (hex or torx) bolt one size larger, and hit it with some black spray paint before installing it.
One other possibnility - you might be able to drill out the rivets, take YOUR piece off the door, and mash it in a vise to 'flatten out' the area of the slot - maybe the metal just bent inwards, and by flattening it again you'll get grip with the stock screw. Then just rivet it back into place.
Old Apr 23, 2011 | 07:24 PM
gta90's Avatar
Sounds great. Thank you both.
Old Apr 23, 2011 | 08:08 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Put a plastic anchor on it.BAM,DONE
Old Apr 24, 2011 | 02:17 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Why dont you just pry the metal back to close the gap.This would make the hole smaller, letting the screw bite again.
Old Apr 24, 2011 | 05:08 PM
mantaguy's Avatar
Engine: 5.0 EFI
Hotrodboba400
Dec 10, 2019 07:07 PM
billybob6110
Sep 23, 2015 01:30 PM
Amillionoh7
Sep 5, 2015 11:44 PM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
