installing 90 steering wheel in my 86
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
i want to swap my old 90s steering wheel into my car, what all do i have to change? i know the horn wires have to be changed, but does anyone have a step by step on this and what all needs changed? please and thank you
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: installing 90 steering wheel in my 86
1990 car has an airbag - you sure you want a non-functioning peeling up air bag wheel in your car?
Engine: L31 350
i know its got an airbag, i think these kind of airbags are sportier than the square i have now lol, and my square steering wheel is broken anyways and help together with trim glue. and the steering wheel i pulled isnt peeling
Engine: LS1, LB9, L03
Good point...I think anything is an upgrade over the standard 86 steering wheel, airbag or not. That being said, there will be a yellow plastic collar and associated wiring for the airbag steering wheel...I'd probably want to take every precaution in making sure there's no way that steering wheel will ever get 12 volts again just so the thing doesn't go off.
In other words, I'd cut/remove any airbag-related wiring, including the yellow collar.
Engine: L31 350
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
It should be the same as my 91 and the horn wires were attached to the two buttons on each side of the air bag. When I pulled it I unhooked the horn wire and have it with the wheel. I would ask if the horn wires are with your 90 wheel. If so just hook them up. They will work fine even though the yellow ring isn't there. If not are the horn buttons on the 90 wheel and if so any of the wire? Take the piece from the older wheel and splice the horn wire leads to it.
Engine: L31 350
iv got all the wires and buttons with the 90 wheel
The plastic piece that you push in and turn to release is the same as the earlier horn piece. Hook it up as the other came apart and you should be good. Just one other thought is that because we have to cut to put an earlier wheel on in place of an airbag wheel I would assume that you may have a bigger gap between the base of the steering wheel and the plastic around the column.
backtothe80s
Sep 5, 2015 12:39 AM
