How to re-attach door sweeps and door panels?
Old May 12, 2011 | 05:53 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I Need to re-attach the door sweeps to the top of the door sill. Looks like the rivets are missing.
I was thinking small screws. Anyone have a tip as to the best way to go about this?
Also, whats the best way to remove the metal clips (gray round metal things) from the door sill so I can attach the door panel?
Old May 12, 2011 | 06:34 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: How to re-attach door sweeps and door panels?
a hot glue gun has worked well for me in the past . just use good glue sticks . the little round fasteners should come off with a pulling and twisting motion . good luck .
Old May 12, 2011 | 08:18 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Mine came apart also but a bit of drilling out the holes installing a few rivets
and some hot glue gun engineering and it came out better than new!
The factory only melted over the tabs to hold everything in place........
Old May 12, 2011 | 09:39 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
For the metal nuts/clips, I was able to use needle nose pliers by spreading them out in the hole and then twisting. It takes patience.
Old May 13, 2011 | 09:23 PM
Car: 89 IROC
Thanks for the tips guys. I'll be putting these back together next weekend.
Old May 14, 2011 | 10:17 AM
my82roc's Avatar
Car: 89 Iroc Convertible
The spin on nuts come off by spinning them counterclockwise.I used a needle nose pliers on the outer edges.You might have to pull up on them while you turn them.I know thats what I had to do with mine.
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
May 7, 2016 06:23 PM
tglennon11
Sep 23, 2015 05:30 PM
NiG
Sep 7, 2015 11:25 PM
84 TA NV
Sep 6, 2015 08:02 PM
