140/145 speedo ???
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
140/145 speedo ???
i have seen many requests and sales of the 145 speedometers on here . i feel 99.5% are wanted just for the "eye candy" effect . how many people really go over 100 mph . (yes , i know some are going to say several times a week) not too many in my opinion . question is can one use the gauge overlays for 145 on a regular 110 speedo and then change the vss or drive gear and get a working speedometer ? seems to me it could be done . but , i could be wrong . (just ask my ex-wives) just a question that has been on my mind for a while . thanks , good luck .
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: 140/145 speedo ???
I don't know about your question, but i like the part about being wrong, just ask the ex's.
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
1/4 mile runs always see it over 100MPH (129/134 MPH)
thats with the right speedo/rear end gear & tire size (12.5x29x15)
Car: 92 z28
Engine: fast burn 385
Transmission: t56
there is no difference in the vss's - there can't be. the 145 speedo works as soon as you swap the cluster, nothing else gets changed. thats how i did it with mine, it worked as soon as swapping the cluster
I have always wondered this too, I thought I read this on here (or I might have dreamed it up) but I thought there was something in the cluster you could change that would make it a 145 mph cluster (with the overlay of coarse) sort of like the board you can change or fix for the tach. But with the 145 mph clusters being worth their weight in gold I would assume it's not that easy, hopefully someone will chime in with some more knowledge on this subject. Btw I would want one for the eye candy effect myself (getting old sucks 10 years ago I would have used the whole 145mph
) Thread
Elephantismo
Feb 13, 2019 12:51 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
