re installing rear hatch trim.
Old May 29, 2011 | 11:27 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
i kinda forgot about this till today but i was never able to re install my rear hatch trim cover thing that goes around the hatch latch and that covers up the spoiler bolts. any hints or tips?
Old May 29, 2011 | 11:37 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: re installing rear hatch trim.
Did you get a replacement piece? Or is it the original one for your car?
It really just fits over and tucks under the rear Hatch weather striping.
Hopefully its a exact fit, if it fits down nicely over the hatch motor and closes then you just scew the plactic nuts in.
But if your talking about the plastic hatch upper cover piece it just scews in.
Old May 29, 2011 | 11:40 PM
Engine: L31 350
the upper hatch cover, but i cant get it to slide in or fit back in so i can screw it in.
Old May 29, 2011 | 11:47 PM
Engine: MPFI
Is it possible to post picture of part you fitting in? I am a little confused.
I Don't know of a part that wouldn't line up, other then the hatch motor cover.
And that would only happen if its the wrong piece for your car.
Old May 30, 2011 | 02:59 AM
85z28kid's Avatar
Car: 85 iroc-z28
Engine: 049 headed bbc 4?? C.I.D
Axle/Gears: 3:73 posi
open your hatch and look up thats the peice hes talking about and it normally fits right for me never had a problem
Old May 30, 2011 | 03:01 AM
Engine: MPFI
I know it only has small scews.
Old Jun 6, 2011 | 03:50 PM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
it hooks at he leading edge. push it up against the glass and pull back to the rear. its usually pretty tight. then the 2 screws at the corners.
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
