power window failure
Old May 31, 2011 | 06:39 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
My passenger window is petering out. I rolled it down, and it quit. I had trouble going up of course stopping, starting, and so on. Any suggestions would be appreciated.
Old Jun 1, 2011 | 05:03 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: power window failure
I have the same problem on the same door.
you are going to need a new power window motor. I would also suggest you get a power window regulator as well.
Old Jun 1, 2011 | 05:34 AM
Would the regulator cause the problem and not the motor?
Old Jun 1, 2011 | 06:23 AM
KITT1983's Avatar
it was my window motor failed but right after I installed the pw motor the power window regulator failed.
it is a good idea to have just in case it fails
Old Jun 1, 2011 | 06:51 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
You're going to have to replace the window motor. If you are going to use the bolts supplied (and not new rivets), it makes it easier if you use a dab of JB Weld to hold the nuts on the back of the motor housing. Thread the bolts by hand to get them started then put the wrench on them.
Old Jun 1, 2011 | 04:33 PM
JB weld? wouldn't lock tite work the same?
Old Jun 1, 2011 | 08:06 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Do a search for the word "bogus" and you'll find the motor replacement thread that makes life super easy.
Old Jun 1, 2011 | 09:29 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
moitors fatique due to worn regulators,check your prices first,found i couuld get a motor and regulator seperately cheaper than buying reulator w/motor'the motors are just windings,and easily fixed
Old Jun 2, 2011 | 06:37 AM
naf's Avatar
naf
I wasn't clear. Use the JB Weld to hold the nuts to the back of the motor until you position it and thread the bolts. Otherwise it's near impossible to finagle the nuts onto the bolts inside the door with the motor in position.
Old Jun 2, 2011 | 04:14 PM
I see. I thought you were using JB to keep the nuts from loosening.
Old Jun 2, 2011 | 08:01 PM
Car: 1992 RS
Engine: Carbed 350
Hot Glue works also for holding the nuts in place until you get the screw through it - just need to hold those little suckers on there until you get the screw started into it - like gluing the lug nuts on a race car wheel.
I also just ordered 2 window motors from 1A Auto - $59.90 with free shipping. (1A Dan is a member here).
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
