Hi i have a question on the B&M T handle shifter. Would Just the handle and trigger work?Or would i have to get the whole thing from B&M.
http://www.bmracing.com/PRODUCTS/Per...irdwithconsole
Thanks for the help in advance.
Slash
close
- Join DateOct 2009
- LocationNew York
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car1988 Camaro IrocZ
- EngineHolley Stealth Ram 385 Stroker
- TransmissionRedline Performance 700r4 Trans
- Axle/GearsBulletproof 4thGen Ls1 SS Rear 3.73
- Liked:0 Times in 0 Posts
the whole point of the megashifter is that it's a ratchet shifter. It'll allow you to shift while driving an automatic and not **** ur tranny lol. it stops after each shift so u dont go to far and say drop it into wrong spot and go *ka-boom*
Ok im just trying to find a nice shifter handle to replace my broken one. I liked the look of this but its so expensive. Thanks btw
Also if anyone knows of a place to get shift ***** for an automatic that would be nice.
navy02ws6
close
Quote:
Originally Posted by 86_sportcoupe
Also if anyone knows of a place to get shift ***** for an automatic that would be nice. Junkyard is going to be your best bet. I'm guessing you have the ball style shift ****, and the stick has broken the top of it off, leaving the ball sitting on the bottom of the stick on the shift plate. Pretty common.
I have a shift **** out of a '90 camaro if your interested.
Quote:
What i would really like is a t-handle or something besides stock. but thanks for mentioning it.Originally Posted by jakemussman
I have a shift **** out of a '90 camaro if your interested. Quote:
Your good. thats exactly my problem. but i dont know of any junkyards in my area.Originally Posted by navy02ws6
Junkyard is going to be your best bet. I'm guessing you have the ball style shift ****, and the stick has broken the top of it off, leaving the ball sitting on the bottom of the stick on the shift plate. Pretty common. Member
In that link you posted there is a T handle in the Related items section right below that.
heres the link to the handle http://www.bmracing.com/PRODUCTS/Aut...ushed-aluminum
if thats what your looking for
No because i have an automatic trans i need something with a push button. and i dont think that will fit. but thanks anyway.Originally Posted by evol
In that link you posted there is a T handle in the Related items section right below that.heres the link to the handle http://www.bmracing.com/PRODUCTS/Aut...ushed-aluminum
Quote:
Ok at this link http://www.bmracing.com/PRODUCTS/Aut...er-AccessoriesOriginally Posted by 86_sportcoupe
No because i have an automatic trans i need something with a push button. and i dont think that will fit. but thanks anyway. they got the cable with them i guess i dont know what stock looks like as i have not had it apart
there are two T handles with buttons(one is standard and the other is metric) says they are currently unavaliable through estore but says to contact them
The buttons on those are a momentary push button, they only work for electrical applications, ie: NOS. Originally Posted by evol
Ok at this link http://www.bmracing.com/PRODUCTS/Aut...er-Accessoriesthey got the cable with them i guess i dont know what stock looks like as i have not had it apart
My stock handle is the round ball version, when i took it apart the other day it was the shifter shaft with a piece of plastic in the middle, this plastic has to be pushed down before it can be shifted into a different gear.
Thanks everyone for all the replys. i decided to make my own handle out of wood and paint it.
I started a thread in case anyone was interested.
https://www.thirdgen.org/forums/fabr...fter-****.html
Got to love that thin little strip of plastic, its amazing they made it so ridiculously frail, broke mine pulling apart my interior just by bumping into it...I mean there is just so little material there, especially where it has that little hole...
Quote:
Yeah i know. You would think they would have made it a little more stable.Originally Posted by Project 3.4 Camaro
Got to love that thin little strip of plastic, its amazing they made it so ridiculously frail, broke mine pulling apart my interior just by bumping into it...I mean there is just so little material there, especially where it has that little hole... Supreme Member
yeah, either metal and or without that little hole in the middle, but oh well, my megashifter is almost done swapping in, so for me its not that bad since I planned on getting one at some pt anyways, but it would suck if I wanted to keep the car original, or didn't want a megashifter.
