E-brake Rattle fix?
Old Jun 19, 2011 | 01:22 PM
faubertt's Avatar
E-brake Rattle fix?
Good afternoon - I've recently noticed that one of the rattles inside my car is coming from the emergency brake handle. Specifically the button above the grip. I would assume this is happening as the spring that would force the button up is weaker than it was originally so there is less tension holding the button firmly in place.
Anyone have a similar problem and know a fix? I can't quite see how the lever/button comes apart to simply replace the spring.
Thanks!
Old Jun 19, 2011 | 04:55 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: E-brake Rattle fix?
I had the same thing going on, drove me nuts. I even stuck a folded up towel next to the lever for a while, but that was equally dumb. I tried everything I could but never found anyway to fix it. Ended going to the JY and rattling every one I came across until I found a solid one. Got that, swapped over and smiling ever since
Old Jun 19, 2011 | 07:31 PM
faubertt's Avatar
Thanks Henry - I'll keep that in mind. Might try to wind a smaller spring underneath it first though. Other thoughts are welcome!
Old Jun 19, 2011 | 08:08 PM
3.4 grape's Avatar
Car: 94 Camaro
Engine: 3.5 turbo
Transmission: Performabuilt 4l60E
Axle/Gears: Strange rear, 3.42
Maybe some grease will shut it up.
jrdturbo
Mar 31, 2016 02:58 PM
David Frans
Oct 31, 2015 08:12 PM
NZKnight
Oct 15, 2015 02:47 PM
z28joe2
Sep 28, 2015 05:54 PM
mfp189
Sep 27, 2015 09:25 AM
