lock/unlock switch 92 firebird
Old Jun 30, 2011 | 07:27 AM
bdawg23's Avatar
Car: '92 Firebird + '06 Charger R/T
Engine: Firebird 3.1L V6
Transmission: Firebird Automatic
I'm trying to figure out how easy it is to replace the lock/unlock switch (drivers side) in a 92 firebird.
seems pretty clear cut on a firebird older than mine... I can't find any info on how to replace mine.
thank ya
Old Jul 2, 2011 | 01:36 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: lock/unlock switch 92 firebird
Same as any other year.Major diff is the trim bezel.
Old Jul 2, 2011 | 02:02 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Very easy. Pop out the little "Firebird" plastic trim. Unscrew the torx bolt. Pop out the sliding orange/black lock lever. Slide the whole trim forward past the inside door handle. After you get the trim loose, unplug the switch. Then you can remove and replace the switch. It's retained in the trim by a couple of plastic tabs that you have to gently open up to remove the switch.
Old Jul 2, 2011 | 04:53 PM
bdawg23's Avatar
Thank eseibel!!! much appreciated! :-D
Old Jul 10, 2011 | 10:47 PM
bdawg23's Avatar
thanks again eseibel!! you were 100% correct!
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
Dialed_In
Aug 20, 2015 01:45 PM
355sbcTPI
Aug 19, 2015 04:38 PM
