Need help putting in a dashboard.
Old Jul 7, 2011 | 07:26 PM
James-Ingram's Avatar
I put my dashboard back together but i'm having a hard time with the harness and fuse box.
I got the dash bolted in real snug, when I mounted my steering column back up the harness got stuck right above it and I can't get my speedo wire for the gauges to come out far enough to hook it up.
If I slide the harness down a bit the column won't go all the way up b/c the harness is in the way..
When I put the dash back together it had a metal bar run all the way through it and the air ducts on it, looking at the dashboard in it now I can't figure out where to mount my fuse box.
I also forgot to mount my passkey box, where does that go?
Jake_92RS
Jan 28, 2020 10:37 PM
dyeager535
Aug 28, 2015 08:10 AM
michealleger
Aug 26, 2015 03:29 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
Fronzizzle
Aug 9, 2015 01:15 PM
