Squeaky GTA Drivers Seat
Old Jul 14, 2011 | 11:23 PM
SeanO23's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI
Axle/Gears: Posi 3.27
whats the best way to eliminate this maddening squeak, WD40?
Old Jul 16, 2011 | 07:43 PM
Sparkko's Avatar
Car: 1988 Firebird Formula
Engine: 5.0L 305 TBI
Re: Squeaky GTA Drivers Seat
You'll have to be much more specific.
Does it squeak only when adjusting or when your driving as well?
Most of the time some lubrication will help.
Old Jul 16, 2011 | 08:38 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Take it apart and check the seat tracks. My pass one had same issue upon tear down found the roller in the adjustor was bad. I replaced from a junkyard pull.
Old Jul 16, 2011 | 11:46 PM
SeanO23's Avatar
Engine: 5.7 TPI
ya its mostly if i move it forward and back when i get in or when im driving around
Old Jul 17, 2011 | 10:13 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Try some lithium grease, it's thicker and will stick better. Make sure to use a straw though, or else it'll make a mess.
Old Jul 17, 2011 | 08:30 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Try tightening the floor bolts,mine squeaked after I put the seats back after I put new carpet in.
Old Jul 17, 2011 | 08:49 PM
SeanO23's Avatar
Engine: 5.7 TPI
i think it has something to do with the connection from the bottom to the back rest, also theres a little toggle thingy i assume used to lock the seat upright and that you could pull to allow people to sit in the back, but now the seat just goes down when u pull it down. also when i brake hard at a stop light the passenger seat comes slamming down.
lee01
Apr 9, 2016 01:56 PM
zayne0
Aug 24, 2015 07:22 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
Mister_Johnny99
Aug 14, 2015 12:59 PM
scottmoyer
Aug 9, 2015 10:18 PM
