89 IROC rear view mirror slipping down
Old Jul 15, 2011 | 09:03 AM
Jbsteven's Avatar
There has to be a easy fix for this. I tried putting a dab of super glue on the metal "ball" to freeze it in place. Worked for a little bit but need a permanent fix.
Ideas?
Old Jul 15, 2011 | 09:19 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: 89 IROC rear view mirror slipping down
get a new one? or even a used one from a junkyard, they came in SEVERAL cars.
Old Jul 15, 2011 | 09:21 AM
Jbsteven's Avatar
Yes, that's always an option. This is from my 11,000 mile car so I want to keep the original.
Old Jul 15, 2011 | 01:32 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
What mirror do you have in it? The auto dimming mirror or a standard mirror?
Old Jul 15, 2011 | 02:20 PM
Jbsteven's Avatar
Auto dimming
Old Jul 15, 2011 | 05:03 PM
scottmoyer's Avatar
Have you taken the mirror apart? It's been many years (like 10) since I even opened mine up. Is it the ball at the back of the mirror or in the arm? I'm thinking there is an adjustment screw that you can tighten. Again, it's been awhile since mine was off the car, but the only thing that would make it loose is either it's broken or an adjustment needs to be done. In 11k miles, I'm thinking adjustment. Let me know what you find.
Old Jul 16, 2011 | 05:22 AM
puma1552's Avatar
Pics of the car?
You've got quite the impressive list of toys in your sig.
Old Jul 16, 2011 | 07:52 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
There's no adjustment possible.The arm is crimped around the ball ends.Maybe some red loctite wil do the trick or re-crimp the arm around the ball ends.
Old Jul 17, 2011 | 08:49 AM
Jbsteven's Avatar
the wire for the lights seemed to be kinda tight so I twisted the clamp that holds it to give it a little less tension. We will see if that fixes it.
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
mustangman65_79
Aug 11, 2015 03:17 PM
89FormulaMan
Aug 10, 2015 10:01 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
