Center console plastic
Old Jul 18, 2011 | 06:29 PM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
I have an auto car and was wondering how to take off plastic around auto shifter, 87 firebird if that helps
Old Jul 18, 2011 | 09:11 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: Center console plastic
I have a Camaro, but it should be the same. Take off the shifter **** (should be a small pin on the rear of the shifter - put into 1st gear for easier access and then pull upward to remove). Then, using a torx bit, remove the plate. Here's a link to an Ebay page of what it should look like (provided we're talking about the same part). http://cgi.ebay.com/ebaymotors/FIREB...Q5fAccessories
Old Jul 19, 2011 | 11:38 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Remove Two screws under the console lid,one under the ashtray then remove the shifter handle by pulling out the horse shoe type clip in the front of the handle,move the shifter back to drive lift up on the plate from the rear and guide it out to clear the radio pod,then remove the window and mirror switches and unplug the lighter and that's it.Good Luck.
OH and be careful with the switches they break easy!!!!!!!
Veaceonee
Sep 29, 2016 08:15 PM
RyanJB
May 7, 2016 06:23 PM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
codeysabatini
Sep 20, 2015 11:36 AM
88HARDTOPIROCZ
Sep 18, 2015 10:30 PM
