1983 camaro dash cluster question
Old Jul 29, 2011 | 08:38 PM
donnam's Avatar
Car: 1983 Camaro
we are putting a 305 v8 in a 1983 that has a v6 in it now will this dash cluster work and what is the yellow box on the back of the tack
thanks
Old Jul 29, 2011 | 09:00 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 1983 camaro dash cluster question
Welcome to TGO, donam.
I'd suggest a V8 cluster. The yellow box is the VSS.
JamesC
Old Jul 29, 2011 | 09:12 PM
donnam's Avatar
Car: 1983 Camaro
thanks for the answer, i did see a thread that explained the vss
Old Jul 29, 2011 | 09:56 PM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
what does the vss do?...
will it work on the 83 camaro?...
i tired putting it on my 83 camaro and the rpms jump all around...
Old Jul 30, 2011 | 06:15 AM
JamesC's Avatar
Here's the way it works from my 85 GM Shop Manual:
"This is the device that will supply the vehicle speed input to the controller. The optic head portion of the VSS is located in the speedometer frame. A reflective blade is attached to the speedometer cable/head assembly. The reflective blade spins like a propeller, with its blades passing through a light beam from a L.E.D. in the optic head. As each bade enters the L.E.D. light beam, light is reflected back to a photocell in the optic head causing a low power speed signal to be sent to a buffer for amplification and signal conditioning. This amplified signal is then sent to the controller."
In short, the VSS sends a signal to the ECM and to the cruise control module on your car (since your speedo is cable driven). It does not affect how the speedo or trip odometer reads.
Your 83 should have one.
To the OP: You may find the link below interesting:
https://www.thirdgen.org/forums/inte...atability.html
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
tnrednneck
Aug 13, 2015 08:57 AM
Vintageracer
Aug 11, 2015 08:13 PM
