How do I remove this piece?
Car: 1986 IROC-Z28
Trying to remove the piece right in the middle on top that sends air to the middle a/c vents, any help appreciated.
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: How do I remove this piece?
Cali, ya might have to un bolt the 4 main bolts that hold the dash to the firewall. that or just do the top 2 and slightly lean the dash back.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
It's been a long time - but I think there are 7mm screwheads (need a 7mm socket) down inside - use a mirror and look down along the sides of the piece you want to remove - it should unscrew and pull upwards out of the dash.
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Glowsock
Aug 26, 2015 12:28 AM
