Old window tint
Old Aug 1, 2011 | 10:04 PM
bigd077770's Avatar
Car: 1998 Trans Am/1992 Camaro RS
Engine: LS1/5.0L TBI
Transmission: 4L60E700r4
Axle/Gears: 3.23/2.73
Old window tint
Hey guys i just got 1984 Z28 and the rear hatch has some really old window tint thats bubbly qnd gross i tried to scrape it off where the defroster grid isnt but i need to get it off, any ideas how to effectively remove it?
Old Aug 1, 2011 | 10:09 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Old window tint
iv heard of some putting an amounia solution on( dont quote me on that as idk what it is) and putting a trashbag ontop of that thats covering the tint then close the car up( windows up, hatch closed, t tops on ect) and letting it sit in the sun for a few hours to the bag can grab the tint then just pull the trashbag off and walla!
Old Aug 1, 2011 | 10:10 PM
SinCityLocal's Avatar
Car: 1990 Mazda B2600i Cab Plus L98 Swap
Engine: 5.7 TPI, LT1 cam, 24 lb. Inj.
Transmission: BowTie Overdrives Level 2 700R4
Axle/Gears: 3.909
Re: Old window tint
You can spray some Windex(with ammonia) on it and cover it with Saran Wrap.
The ammonia will soften the adhesive and you can use a soft scrub brush.
It's gonna take some time and patience.
Old Aug 1, 2011 | 10:14 PM
bigd077770's Avatar
Re: Old window tint
It seems kinda messy, how about a heat gun
Old Aug 2, 2011 | 08:09 AM
Engine: L31 350
Re: Old window tint
heat guns work but its alot longer and you risk damaging the defroster grid in process. the bag trick, or the wrap trick works the best and the fastest
Old Aug 2, 2011 | 09:18 AM
andy74's Avatar
Car: 1988 gta carbed 383
Engine: small block 4bbl
Axle/Gears: 3.27 g80
Re: Old window tint
i ve had good luck using windex and plastic razor blades on side windows-the saran wrap trick works,i watched a guy do it at the dealership many times
Old Aug 2, 2011 | 10:18 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Re: Old window tint
I took my whole hatch off and turned it upside down on the ground. I scraped off the loose stuff, sprayed it with windex, then put black plastic over it to heat it up.
After I got all of the film off, the sticky adhesive was still there, so I used some Goof-Off and paper towels for that.
Old Aug 2, 2011 | 02:15 PM
R/T-Z28's Avatar
Re: Old window tint
I would take it to a tint shop. They charge about $5-$10 bucks to remove it and it takes about 5 minutes. Looks perfectly clean like if it was a new window.
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
