diagrams for ac/heating vents HELP!!
Old Aug 5, 2011 | 06:14 PM
DukeDelavega86's Avatar
Does anyone have pictures or diagrams of the vent routing behind the dash? I am having problems with the flaps and I need to see what I am trying to fix help please...
Old Aug 5, 2011 | 06:39 PM
torque_is_good's Avatar
Re: diagrams for ac/heating vents HELP!!
now hold on there junior.
please tell us the symptoms, not what you think is the cure.
Is your HVAC system perhaps only blowing out of the defroster?
If so, go reconnect the vacuum actuator line under the hood.
Old Aug 5, 2011 | 09:55 PM
AgentCharlez's Avatar
Car: 1991 Camaro RS
Engine: TBI 5.0L V8
I had trouble with my vent flaps before too. It turned out to be a blocked vacuum line. It might be the same for you. Here's the diagram I used to troubleshoot it.
Old Aug 6, 2011 | 07:04 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by torque_is_good
Is your HVAC system perhaps only blowing out of the defroster? If so, go reconnect the vacuum actuator line under the hood.
Welcome to TGO.
Or the leak might be at the Valve Vac Sel GM part # 16032395. The switch is located on the pass side at the rear of the controls. Stick an ear to that area and listen for the telltale hiss.
JamesC
Old Aug 6, 2011 | 09:34 AM
Originally Posted by JamesC
Welcome to TGO.
JamesC
where are my manners? You are a newb. I don't even look at the stat on the left.
yes, welcome to tgo
now please don't get ahead of yourself ripping apart stuff.
InfernalVortex
Apr 20, 2021 11:31 AM
Pac J
May 17, 2020 10:44 AM
Fanatic1074
Oct 2, 2015 03:47 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
tattmann
Sep 27, 2015 05:20 PM
