very loose steering column
Old Aug 5, 2011 | 07:56 PM
blackbeauty89's Avatar
Car: 1989 Pontiac GTA/2007 TrailblazerSS
Engine: 350 L98/LS2
Transmission: 700-R4/4L70E
Axle/Gears: 3.27/4.10
as title says, i have a loose steering column where the wheel is supposed to tilt. it tilts normally and locks and everything, but there is QUITE a bit of play. i can essentially move the column in a circle. most of the play is up and down. would i need to get a whole new column or can i replace just the part that tilts?
Old Aug 5, 2011 | 08:31 PM
torque_is_good's Avatar
Re: very loose steering column
interesting. have you ever used the search feature on this site? There is a wealth of information and you don't have to wait for replies
https://www.thirdgen.org/forums/susp...-steering.html
Old Aug 6, 2011 | 01:16 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
All GMs with tilt have lose tile bolt problems, loctite wasn't used.
1 needed special tool, tilt piviot pin puller, must have.
Old Aug 6, 2011 | 09:54 PM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
have you tried tightening the bolts that hold the column in place under the dash, mine were loose after i replaced the heater core, your problem sounds similar to the play in mine, i could move it side to side and up and down alot
armybyrd
Sep 28, 2023 12:16 AM
Night rider327
Sep 25, 2015 04:19 AM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Tweeks25
Sep 17, 2015 08:04 AM
Ian Irvine
Sep 4, 2015 08:08 AM
