85 z28 door lock issues
Old Aug 10, 2011 | 09:06 PM
n8sz28's Avatar
Car: 85 camaro z28
Transmission: T56 6 speed
Axle/Gears: 3.27 borg warner 9 bolt
I had the whole issue of my door locks not locking 100% so i decided to clean them up and lube them like all the other posts said to due. I was testing the locks when the motor stopped working almost like it was worn out and needed a break. It then worked again like 15 minutes later. not it has been a few hours and it still doesn't work again after i was messing around with it again. i did disconnect the motor and plugged it back in along with test the power to it. the power is getting to the motor. any suggestions
Old Aug 13, 2011 | 04:45 AM
camarosource's Avatar
Car: Custom 1992 Camaro Z28 25th Anniver
Engine: 5.7L V8 350 L98 TPI
Re: 85 z28 door lock issues
No problems with the switch? Are you positive that power is always leading to the motor? How old is this motor?
Old Aug 13, 2011 | 09:34 AM
n8sz28's Avatar
Car: 85 camaro z28
Motor is original. Got it to work for now. Took door panel off and it just started to work again. Gonna see how long it lasts
Old Aug 13, 2011 | 10:57 AM
This is the original factory motor? (26 years old)?
Old Aug 13, 2011 | 12:09 PM
n8sz28's Avatar
Car: 85 camaro z28
As far as I know both sides are still original so yah 26 years old
Old Aug 13, 2011 | 09:47 PM
I THINK the door actuator is also riveted by the factory (as well as window motor) unless I am wrong about the door motor..
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
