T Top Headliner Restoration
Old Aug 14, 2011 | 06:11 PM
geoff jaymes's Avatar
Car: 1987 Pontiac Trans Am
Engine: LB9 305 TPI
Axle/Gears: Limited Slip, possibly 2.73
Hey Guys. Just thought I'd share my little project with the TGO folks. I bought my 87 TA with no headliner or molding at all. One of the probably many previous owners ripped it all out. I got sick of looking at the bare frame, so I pulled out a decent t top molding out of a buddy's z28. the fabric was wasted, but the molding was usable. I went and got me the fabric, which actually matches pretty good to the original grey. It was my first time though, and the 4 inner corners got me as you can see. I will probably re do it again soon, but here's some pics. Not bad, for a car with no headliner or molding when I got it. I'm also going to re do my sail panels with left over scrap material. Those will be cake, compared to the headliner. I also have a bunch of sail panels with bad fabric on them, and was thinking about re doing those as well. Like, grey, red and black. Possibly posting them on here for sale or whatever. Let me know what you think for a beginner. Thanks.[IMG][/IMG]
Old Aug 17, 2011 | 08:56 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: T Top Headliner Restoration
great job for your first try. these things are very tricky and the type of material you use can make or break ya. Because of all the corners and turns on the t-top cars, a stretchy material will make things a bit easier to tuck without cutting.
if you ever decide to give it another go, i'd also recommend putting down a layer of resin and fiberglass cloth. the fiberboard gets weak on these headliners and fall apart when they get wet, a bit of fiberglass can help fix this
Old Aug 18, 2011 | 01:16 AM
Engine: LB9 305 TPI
Thanks for the comment, and I'm actually considering the idea of re doing the headliner again, because every time I look at those corners, it bugs me. I know I can do it much better to where it would look flawless all the way around. When I do decide to tear it all out again, I will definitely get some resin to strengthen the fiberboard, I don't know how much more moving around mine can handle! Thanks again.
Old Aug 19, 2011 | 05:59 PM
Kelby Jones's Avatar
Car: 1985 Camaro Iroc-Z
my camaro didnt have a headliner when i bought it so i found one from a wrecked hardtop car and we put it in put the visors and the dome light on and then took the t tops off and started trimmin away wut i didnt need and just tucked it under the weather stripping and glued it with some super 77 spay adhesive and except for some little mess up here and there it looks almost factory
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Golfvette
Aug 24, 2015 06:35 PM
TheJoeY88
Aug 13, 2015 06:51 PM
