Has anybody made a mod for AC controls
Old Aug 17, 2011 | 03:00 PM
AggieIROC13's Avatar
I have seen some in dash radio flat touch screens that fit 2-din areas modified to fit in a camaro radio spot, I was wondering if anybody has modified their AC/Heater controls to also work on a touchscreen there and delete the original controls, they look old with a new screen there
Old Aug 18, 2011 | 12:15 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Has anybody made a mod for AC controls
not necessarily an easy feat in our cars, as the vents are controlled by vacuum and the temperature is controlled by cable. it would have to be an in dash pc (no radio had these capabilities) and you would have to come up with some kind of motorized setup. newer cars are easier because they're done electronically with actuators at the vent and temperature doors.
Old Aug 18, 2011 | 02:12 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Fiero's have electronically controlled vents and such, and so did some GTA's.
Maybe you can adapt one from a fiero or GTA to work in your third gen?
Old Aug 18, 2011 | 04:30 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
I don't understand why people buy old cars and then expect them to look modern (by 2011 standards). Tastefully done mods will blend in well with what's already there, not stick out like a sore thumb.
Old Aug 18, 2011 | 05:18 PM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
I absolutely agree with you. This is one reason I'm not a fan of the 4th gen dash and console swap. IMO, I like to keep our cars as original as possible. Sure an upgraded radio, but a simple one. Why tear apart a perfectly good looking car already and "modernize" it? Kind of takes away the feeling of owning a classic car.
Old Aug 21, 2011 | 07:06 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
its getting hard to find aftermarket 1.5 din radios and i refuse to adapt the hole down to single din.what id like to have is a plate that brings the heater controls out flush and as high as possible to run a double din radio without notching the bottom.
NORTz89
May 20, 2020 03:51 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
haps
Interior Parts Wanted
Sep 8, 2015 10:15 AM
lakeffect2
Aug 23, 2015 08:44 AM
Street Lethal
Aug 12, 2015 11:33 AM
