covan classic dash panel
Old Aug 22, 2011 | 02:57 PM
crazy82's Avatar
i bought one of these panels from summit, it's to short and the holes don't line up. sent it back and summit is gonna send another one . just wondering if anyone ran into this, i dont wanna send the second one back .
Old Aug 22, 2011 | 03:04 PM
crazy82's Avatar
Re: covan classic dash panel
here is a couple of pictures
Attached Thumbnails covan classic dash panel-img-20110820-00025.jpg   covan classic dash panel-img-20110820-00022.jpg
Old Aug 22, 2011 | 03:47 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
did you test fit it to the dash? the dash is not square...
Old Aug 22, 2011 | 04:47 PM
crazy82's Avatar
yeah i had all the guages in it if i screwed the top to middle holes which are the only ones that would fit it was about a 1/8 inch smaller on both sides if i screwed on the bottom corner in on one side nothing lined up, for 124 dollars it should fit perfect
Old Aug 31, 2011 | 05:26 PM
crazy82's Avatar
well got another one from summit today, was the same did not fit at all called summit they gave me the covans number called them. all i can say is they are complete Aholes. he told me he installed hundreds of them (bullshit). there must be something different with the 82 dash. he basically told me you bought it from summit so f==k off . and offered no help as to what could be the problem ,DO NOT WASTE YOUR MONEY on this piece of sh-t plastic make your own as i did.
Old Sep 1, 2011 | 08:42 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
sorry to hear the bad luck. i know the 82-83 dashes have some subtle differences from the 84-90 (or was it 89?), maybe the gauge cluster is one of them. Never had that early of a 3rd gen myself, so haven't been able to compare side by side
Old Sep 3, 2011 | 05:19 PM
crazy82's Avatar
thats what i told the guy from covans, 82 is different he told no he installed hundreds of them i bet he never saw an 82 83 dash . anyway he is a pompus A-- .
Old Oct 21, 2011 | 09:23 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Wow that bl*ws. You go do something that makes your car look a little different and you wind up getting hosed. I was looking at these replacement cluster panels and after pricing them out with some decent Auto Meter gauges the cost was over 9 hundred $$$. Way too much bread for me. So I just replaced all the bulbs with super brights, cleaned up the panel and spray painted the metal frame bright silver so the gauges pop. Looks better than new now.
Old Oct 24, 2011 | 10:33 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
except the factory gauges are inaccurate...
Old Oct 24, 2011 | 10:56 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Are you talking my gauges or any factory gauge?
Old Oct 25, 2011 | 02:30 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
any factory gauge. if they even work.
Hotrodboba400
Dec 10, 2019 07:07 PM
MantyZ28
Nov 8, 2015 06:54 PM
Stryker412
Sep 7, 2015 09:11 AM
84 TA NV
Sep 6, 2015 08:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
