How do I make this headliner trim grey?
Old Aug 22, 2011 | 11:13 PM
Xanity's Avatar
Car: 1989 Camaro
Engine: 2.8 MPFI
Everybody here is familiar with the headliner trim that is the closest thing to the hatch window, and if you, like me, have looked into investing into a new, uncracked one, that they aren't readily available, if at all, in anything but black.
This poses a problem, as my interior is dominantly grey, and putting a black one in would throw off, well, everything. I am curious how I would go about painting this to the common grey that it's supposed to be, and hopefully I'm not the only person who wants to do this. It would help if you even had results from your time and knew what shade of grey would look best.
Thanks everyone.
Dan
http://www.hawksthirdgenparts.com/ca...trimpiece.aspx
Old Aug 23, 2011 | 12:24 AM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: How do I make this headliner trim grey?
SEM paint, is the best. It does not peal or chip off. Just use the right prep. Clean really good, use mineral spirits to prep opening pores of plastic. Then spray with about 3 coats letting it dry in between coats. Here is a link. You can also buy on amazon too.
http://www.tcpglobal.com/autobodydep...FQo0QgodExcf8g
Old Aug 23, 2011 | 12:51 AM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
I think I have a gray one I could swap you. I would have to check when I get home.
Old Aug 23, 2011 | 12:59 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
I used SEM Color Coat (I went from gray to red on the same piece), there's different shades of gray so I'm not sure which one would be correct. Make sure to use adhesion promoter, many people swear by using Bulldog, although I used Duplicolor.
Old Aug 24, 2011 | 10:59 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
camarosrock1989 and 80schild are correct; SEM paint will work and I can confirm that it works awesome!
Check out my SEM success in my most recently posted photos: https://www.thirdgen.org/forums/album.php?albumid=4980
Old Aug 24, 2011 | 11:14 PM
Car: 1990 Camaro RS
I don't have one.
Old Aug 31, 2011 | 12:20 PM
Xanity's Avatar
Car: 1989 Camaro
Engine: 2.8 MPFI
Wow, that looks fantastic! Thanks for the help, now I know for sure what to use!
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
lee01
Apr 9, 2016 01:56 PM
Golfvette
Aug 24, 2015 06:35 PM
TheJoeY88
Aug 13, 2015 06:51 PM
