gauges swap speedo, rpm...questions
Car: 1988 iroc-z
Engine: building a 360 now almost done
Transmission: 700r4 w ratchet shifter
was wondering how hard it will be to change out the speedo and rpm gauges in my 88 iroc-z with like sunpro gauges(cheapo ones lol). i alrdy got a oil gauge thats made into my shift plate. jus need to know wut i need and wut not thx!
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: gauges swap speedo, rpm...questions
The factory uses a flexible printed circuit board for all the connections
in the instrument cluster, and the instruments do not have individual
housing modules. So putting aftermarket instruments into a factory
panel will require considerable effort & fabrication skills.
I suggest find another instrument cluster -- swap meet, classifieds
here on TGO, etc. -- to experiment w/. Cause you won't get the
first one right.
Good luck.
first one right.
Good luck.
Car: 1988 iroc-z
booo, thats to much work then lol ty bro
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
putting in aftermarket gauges requires wither buying or making a new guage panel to hold them, as well as custiom wiring for electric gauges or hose routing for mechanical gauges. not just a bolt in type deal.
Car: 1989 Camaro
Engine: Modified 350 bored out to about 360
ambainb
Apr 25, 2016 09:21 PM
