A-pillar trim weatherstrip guide.
Old Aug 29, 2011 | 06:42 PM
Elthesh's Avatar
Car: 1991 Pontiac Trans Am
I decided to replace my A pillar trim since the sun had melted it so they both formed a nice V shape due to sagging in the center sections. The first step was to obtain new undamaged, unmelted pieces. I then came across an issue where it seems, at least for T-tops, that in mid 91 they changed the design of the trim piece from what they had been using since 1982. Noone could tell me what exactly the difference was. So, I hunted down a factory new trim piece of the newer design for one of the sides and bought a used piece for the opposite side of the previous design since that's what I needed anyway.
The next step was to figure out what to do with the trim rubber seal. The new piece had a brand new GM installed seal whereas the used one had the seal removed long ago, likely due to it falling apart. My own seals were in horrible shape as well. I did some research and located an almost exact copy of the seal. The original seal is some sort of foam or sponge rubber and in roughly a very bent L shape. The seal I found was also rubber, but more of a weatherstrip type rubber. It had the same shape and overall size as the original, but the open part of the L is connected so as to form a cockeyed triangle. The new seal also is of the peel and stick variety as was the original seal.
The weatherstrip can be purchased here and is number 2 in the photo.
http://www.jcwhitney.com/stick-on-re...wx?filterid=j1
Next was to clean the remains of the original sticky material from the old piece so as to get good clean contact with the plastic. I used Goo Gone. Rub some on, wait, rub more on, wait, a little more, then start scrubbing it off with a paper towel. It ALL came off, even though it was dried, hard as a rock and at least 25 years old. You will want to do the same. If you're going through the effort to replace the strip, are you really going to be cheap and lazy and leave the old dried up material there?
Lastly was the purchase new clips. Here are photos of the finished result, comparing both the new and original rubber seals and also comparing the two different trim pieces. One from pre mid 1991, one post mid 1991-1992. I haven't installed them yet so I'm unsure if the difference will matter on my pre 1991 design. The factory new piece with the original seal is the one in the photos with the new clip installed. The other piece does not yet have clips installed. Also, the new piece is dusty since I haven't wiped it down yet.
The photos are large so you can see all of the differences in the rubber seals and the trim pieces.
http://bellsouthpwp.net/E/l/Elthesh/IMG_0765.JPG
http://bellsouthpwp.net/E/l/Elthesh/IMG_0766.JPG
http://bellsouthpwp.net/E/l/Elthesh/IMG_0767.JPG
http://bellsouthpwp.net/E/l/Elthesh/IMG_0769.JPG
http://bellsouthpwp.net/E/l/Elthesh/IMG_0770.JPG
http://bellsouthpwp.net/E/l/Elthesh/IMG_0771.JPG
This is a photo of the clips used. The part numbers on the box below the 12992 are the GM numbers I used to find these on Ebay.
http://bellsouthpwp.net/E/l/Elthesh/IMG_0774.JPG
Old Aug 30, 2011 | 09:03 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: A-pillar trim weatherstrip guide.
good info, thanks for sharing
Old Aug 30, 2011 | 11:09 AM
82tarecaro's Avatar
That seal looks better than the original one! I will definitely be doing this on my TA.
Where did you get the new clips?
Old Aug 30, 2011 | 04:44 PM
Elthesh's Avatar
The seal really is better than the original I think. Also, a couple of the pictures kind of make it look like the new one is a bit wider than the old. Not that it would matter, but it isn't.
As for the clips, I actually bought them on Ebay. You can likely buy them almost anywhere, auto parts store, GM, etc. However, I decided against purchasing them one at a time and bought 2 different types since the parts manuals listed two types although only one was correct. I'll take a photo of the clips and add it to the first post. The box of 25 only cost about 5.50 as well.
Hardtops should use the same seal. Not sure what they use on the roof area, maybe more of that seal, but, they will need different clips for that particular area. Those clips would be plastic but also have a foam rubber "gasket" thing to add stability and orevent squeaks I assume.
Old Dec 22, 2011 | 09:08 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
what type of seal did you use ? 1 or 2 or3 ? 10 ft., A=5/8" x B=3/4"?
http://www.hawksthirdgenparts.com/do...rdnewgm-1.aspx
Old Apr 16, 2012 | 09:56 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
[QUOTE=Elthesh;5024319]...The weatherstrip can be purchased here and is number 2 in the photo.
I followed the above link yesterday afternoon and was doing my research. I had some errands to run. Late last night I returned to the task of ordering the weatherstripping and followed the link back to JC Whitney. The page was no longer available. I did a GOOGLE search on the mfr's p/n and found two sources pointing to the same now missing JC Whitney page. I copied all the part numbers and began a chat session with JC Whitney. They were unable to help. They told me to call JC Whitney, which I did. They too were unable to help. Now I'll attempt to find it by calling the mfr.
Lon
Old Apr 16, 2012 | 10:25 AM
Elthesh's Avatar
The bag lists
ASAP, Inc.
Part Number:
13-3202
It's lousy that they don't list it now, and a little odd that they seemed to be the only people in the entire world listing it.
If you can find a source for it and you like the results and all that, you may want to consider putting it up in your store. I know it took me quite a while of poring over image after image of weatherstrip to find it, so your store would make a much better place for it.
Old Apr 16, 2012 | 12:47 PM
86black&gold's Avatar
Car: 86 Trans Am
Engine: 305 HO
Transmission: 350 Turbo
Im confused as to what these a pillar pieces are? I have an 86 trans am and im sure if everyone else is replacing these seals i also should.
Old Apr 16, 2012 | 01:45 PM
lonsal's Avatar
Everyone (including me) needs to replace these seals, but no replacement has been available. The seal is a along between the ABS pebble-finished trim piece covering the A-pillar on the inside of the car and the window. The OEM piece has a flat edge that was secured to the back side of the trim piece with double-sided tape. From that point it is bent at an angle with a curve to it to fill the gap between the trim piece and side window. Yours may be missing or so badly mangled that it no longer resembles what I am describing.
Lon
Old Apr 16, 2012 | 02:41 PM
82tarecaro's Avatar
Wow - that sucks. I should have bought this when the thread was originally started. It's such a simple piece that there has to be another alternative.
Old Apr 16, 2012 | 03:54 PM
Car: 86 Trans Am
Engine: 305 HO
Ok ive realized what they are, but my trim pieces look good. But the seal isn't whats the purpose of the seal?
Old Apr 16, 2012 | 03:58 PM
82tarecaro's Avatar
I think it just fills in that space.
Old Apr 16, 2012 | 04:03 PM
Car: 86 Trans Am
Engine: 305 HO
Ok. Its there just dry rotted.
Old Jun 27, 2012 | 08:25 AM
Bad AZz Z28's Avatar
Car: 89 IROC, 94 Z28 1LE
Engine: LQ9 swaps
Axle/Gears: Dana S60s
any luck on another source for the replacement? I'm re-doing my door seals, handles, and hinges, so I'd love to fix these A pillars as well and have everything looking new.
Old Jun 27, 2012 | 10:03 AM
82tarecaro's Avatar
Here is something I found on Amazon that might work. I have to order it and try it.
http://www.amazon.com/dp/B0053G14TM/...560_pe_vfe_dt1
Old Jun 27, 2012 | 07:20 PM
lonsal's Avatar
Nope.
Old Jun 27, 2012 | 07:29 PM
James76's Avatar
Car: 1984 Camaro Sport Coupe
Engine: 2.8l v6 soon to be 350
Transmission: auto
I was actually looking at my a-pillars this evening trying to figure out if I need to find a replacement seal before putting them back in the car.
I work at a shop where we do truck accessories and when I saw the seal I knew it looked familiar. We get a similar seal with Access brand tonneau covers. I cant find the part number but I am sure someone can contact them to see if they sell just the bulkhead seal kit. It would likely take 2 kits for a hard top.
Old Dec 1, 2012 | 05:05 PM
cdoyle's Avatar
Dang it, I knew I should have bought this last year when I first asked about it.
So nobody else carried it?
Old Dec 1, 2012 | 05:15 PM
82tarecaro's Avatar
That's funny you bumped this topic up. I was just looking at some seals from Steele rubber. They have something that should work. I am going to try to post a pic of it since I can't directly link to the page.
Old Dec 1, 2012 | 06:16 PM
cdoyle's Avatar
Which ones are you looking at? Their site is hard to navigate and not seeing anything.
Thanks!
Chris
Old Dec 1, 2012 | 06:18 PM
cdoyle's Avatar
Maybe these?
part number 83-10131-73
or these?
83-10125-73
Old Dec 1, 2012 | 06:58 PM
82tarecaro's Avatar
This one
Old Dec 2, 2012 | 05:36 AM
KITT1983's Avatar
deleted
Old Dec 6, 2012 | 06:43 PM
soul.justice's Avatar
Car: 1985 Firebird Trans Am
Engine: 305 4bbl
Axle/Gears: 3.08
Thankfully due to the fact that i work in commercial HVAC, I got the five finger discount on three rolls of Ductmate 1" x 1/2" thick rubberized gasket tape. We usually use it to seal Ward/TDC duct connections and roof curbs for units, but I'll be applying it to my A pillar trim this weekend, I'll let everyone know how well it turns out.
I'll also be using this gasket tape on my dash where it meets the windshield and other trim pieces to kill off some squeaks.
Old Dec 7, 2012 | 01:18 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
There's also this option which is a pretty nice fix for this issue:
https://www.thirdgen.org/forums/inte...stic-trim.html
-Eldon
Old Dec 7, 2012 | 05:46 PM
82tarecaro's Avatar
Yep - that looks good too.
Old Dec 8, 2012 | 01:04 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
napa has one that looks and works just like the GM factry seal.
i did a full post with pics...a few months ago
Old Nov 27, 2017 | 03:42 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
JC Whitney links don't work... tired some part numbers in this post, don't work either...
Anyone have new links / part numbers for this?
Thanks.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
