Started head liner and sail panels
Old Sep 4, 2011 | 10:56 PM
mattmerritt89's Avatar
Car: 1987 Camaro
Axle/Gears: 4.56
Pulled out the headliner and sail panels today. Headliner was completely shot. It had water damage from the window seals leaking. I did get to recover the sail panels and they look great, and even got the girlfriend to help. I am going to post some pics of the panels tomorrow.
Old Sep 5, 2011 | 10:38 AM
Car: 1987 Camaro
Axle/Gears: 4.56
Re: Started head liner and sail panels
Here are some pictures of the sail panels and the roof with out the headliner. Think I may put some Dynamat or something while I have it out. Headliner fell apart when I took it out. The sail panels are black, but look grey in the picture. Wish I hadn't ordered a grille for the car from year one. Would have gotten a headliner board instead.
Attached Thumbnails Started head liner and sail panels-100_0879.jpg   Started head liner and sail panels-100_0881.jpg   Started head liner and sail panels-100_0880.jpg
Old Sep 5, 2011 | 11:23 AM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
I have had good luck with this site.
www.camarocentral.com
Old Sep 5, 2011 | 12:41 PM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
my sail panels were coming apart, i just swapped them with the 91/92 plastic sail panels. looks fine. direct swap, and dont have to worry as much about the deteriorating fiber board. id like to find a sturdy as hell ttop headliner tho, not about to use a stock used one regardless of its condition - its too frail.
Old Sep 5, 2011 | 01:00 PM
Car: 1987 Camaro
Axle/Gears: 4.56
Youngsfbody has the hard top one for 95.00 plus 50.00 for shipping, that's the one I'm going to get. But I have to wait a few weeks.
http://www.youngsfbody.com/inc/sdetail/279/66478
Old Sep 5, 2011 | 09:01 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Go ahead and spray some rust converter on that surface rust while you're at it. I had rust in the same exact place.
I got the hardtop headliner kit from Hawks, and I'll admit, my overhead console seems to support it quite a bit. Not sure how well it would work without it.
Old Sep 7, 2011 | 12:05 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Looks good . A nice place to install some 6x9s.
Old Sep 7, 2011 | 09:01 AM
Car: 1987 Camaro
Axle/Gears: 4.56
Yeah it still has the original speakers.
Old Sep 7, 2011 | 12:36 PM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
that site wants $239.95 for a ttop headliner :O
Old Sep 8, 2011 | 12:57 PM
jbird2ooo's Avatar
Car: 1989 IROC
Try 1Aauto.com
Just got an ABS headliner (for 1989 IROC w/t-tops) for $150, free shipping. It's a little more if you want it covered. I'm going to buy the fabric separately and cover it myself.
Old Sep 8, 2011 | 05:46 PM
Car: 1987 Camaro
Axle/Gears: 4.56
Originally Posted by jbird2ooo
Try 1Aauto.com
How long did it take for you to get it?
Old Sep 8, 2011 | 09:20 PM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
Try 1Aauto.com
have pics you could share?..
Old Sep 8, 2011 | 09:36 PM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
how well does it fit?..
Old Sep 9, 2011 | 10:48 AM
jbird2ooo's Avatar
Car: 1989 IROC
It took maybe two weeks to get it. Faster than I expected. I had to increase the cutout for the dome light but otherwise it fit nicely. I decided for now just to install it without the fabric and I like it so I might just leave it.
I'll post a picture as soon as I can figure out how.
Old Sep 9, 2011 | 11:03 AM
jbird2ooo's Avatar
Car: 1989 IROC
Much better than the old torn and disintegrating headliner.
Old Sep 9, 2011 | 11:39 AM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
looks nice!
wonder how compromised the structure would be after cutting areas for the overhead console...
Old Sep 9, 2011 | 01:31 PM
LarryL's Avatar
Car: 84 TA,69 camaro,81 vet 92 vet
Engine: 400
Axle/Gears: 3:73
The overhead console will help hold up the headliner. It screws to the roof. When I added one to my TA the holes were there, so no drilling stright bolt in. Just have to connect the wiring for the overhead light.
Old Sep 9, 2011 | 09:17 PM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
http://www.1aauto.com/1A/headliners/...51/472649/1987
i dont see any holes for the Overhead Console. only the standard dome light.
"All truck and car headliners ship UPS Oversize 1. This product is rolled up in to a box for shipping and must be laid out as soon as you receive it. Please allow 24-48 hours for the headliner to retake its shape before installing."
wtf? - so, would this thing even be able to withstand cutting into or will it shrivel up?
that being said, is there even a company that makes a ttop headliner that includes the overhead console connections pre cut?
Old Sep 9, 2011 | 11:54 PM
LarryL's Avatar
Engine: 400
Axle/Gears: 3:73
There are two screws with no threads close to the screw head, they screw into roof metal. The console slides onto the unthreaded part (in front) and screws on the back of console under the light cover. The front can be a pain to slide in. It must go on first. It took me a while to get them to slide on. You have to push up on console and slide it forward. Look at the top of console you will see the slots.
Old Sep 10, 2011 | 12:19 AM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
i must be blind, im completely missing what youre pointing out..
there would need to be 3 sections (openings)
in order for it to fit correctly seeing as how its shaped like this:
_|__|__|_
vertical lines being connection points. back part being the actual screws that go thru the dome light section.
per the photo of the headliner it appears there is Only the area for the dome
light...
Old Sep 10, 2011 | 04:31 AM
jbird2ooo's Avatar
Car: 1989 IROC
It comes loosely rolled in a fairly large box and doesn't take more than a few hours to flatten. It's sturdy enough. To enlarge the dome light hole I drilled small holes side by side along the outline I wanted. Then snipped as much as I could. To finish I used a dremmel tool. You just have to be careful not to let the tool slip and I used a block of wood under the drill and a small bit so the bit didn't grab. You can't tell I did the cutting. If you had to cut an area for a console, I'd cut it just so the edges of the cutout would slip under the edge of the console (just like the dome light). That actually holds it up quite nicely.
Old Sep 10, 2011 | 11:32 AM
Car: 1987 Camaro
Axle/Gears: 4.56
That does look good. I think I'm going to order the headliner next Friday. I wish Yearone had them a little cheaper I would just go down and pick one up. I might get one from there just so I can get it in next weekend.
Old Sep 10, 2011 | 11:59 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Local Auto Reupholstery shop could do a factory look for less money, effort and time. Those online headlener kits are not + the shipping sharges cheap. I bet no one checked the cost at a local shop.
Old Sep 10, 2011 | 12:57 PM
Car: 1987 Camaro
Axle/Gears: 4.56
All they will do is order a new one. That's what all the shops around here do. At least that's what they said when I asked about it in my old Camaro.
Old Oct 24, 2011 | 07:31 PM
TkernIROC1986's Avatar
Car: 1986 IROC-Z
Engine: 5.7L TPI L98 350
Transmission: 700R4 Auto
Axle/Gears: 10-Bolt Posi Disc 3.73s
My shop told me that I would need to go to a junkyard and find one to recover. I'm pretty sure he doesn't know how shitty the original headliners were in the 3rd gens. I'm going to order an ABS one from Hawks in a few weeks and just have him install it.
Old Oct 26, 2011 | 10:27 AM
stahrman0612's Avatar
Car: 1986 Trans-Am
Engine: 305 4 bbl
Transmission: 700R4 auto
Axle/Gears: posi
I bought one for $75 off a guy who had an extra he bought on ebay. This thing was a pain to install.....lots of bowing. I think I'm going to try and slide the whole headliner back an inch to fit a little better!! PS...did I install my dome light the wrong way??
Old Oct 26, 2011 | 10:37 AM
Car: 1986 Trans-Am
Engine: 305 4 bbl
Axle/Gears: posi
I picked up these black sail panels off ebay several years ago. They have a raised pontiac symbol in them. Kind of hard to tell from pic.
Old Nov 7, 2011 | 06:20 PM
Eightyninef's Avatar
anyone try the hawks aftermarket head liner kit?
for a hardtop?
How does it fit ?
how much of a PITA is it to install?
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Street Lethal
Aug 14, 2015 08:25 PM
z28addict8490
Aug 7, 2015 08:48 PM
